CyberPanel Self-signed SSL certificate
I have just created CyberPanel and start moving my websites from my old cPanel host (also Litespeed server). However, my domains keeps getting self-signed SSL certificates. I have tried troubleshooting using this guide, but that does not solve my problem:
https://community.cyberpanel.net/t/how-to-fix-ssl-issues-in-cyberpanel/90
When I visit my domain https://www.apha.dk I get a NET::ERR_CERT_AUTHORITY_INVALID error. In the browser I can see that the certificate was given by “Dis” and in CyberPanel it says “Apha.dk has self-signed SSL”. When I go to the folder /etc/letsencrypt/live/apha.dk I can see that there is a fullchain.pem and privkey.pem file with a code inside.
My CyberPanel logfile says the following:
[12.08.2022_07-31-52] [Errno 2] No such file or directory: '/etc/letsencrypt/live/apha.dk/fullchain.pem'
[12.08.2022_07-38-28] Status Code: 200 for: http://www.apha.dk/.well-known/acme-challenge/apha.dk
[12.08.2022_07-38-28] Status Code: 200 for: http://apha.dk/.well-known/acme-challenge/apha.dk
[12.08.2022_07-38-30] /root/.acme.sh/acme.sh --issue -d apha.dk -d www.apha.dk --cert-file /etc/letsencrypt/live/apha.dk/cert.pem --key-file /etc/letsencrypt/live/apha.dk/privkey.pem --fullchain-file /etc/letsencrypt/live/apha.dk/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[12.08.2022_07-38-33] Failed to obtain SSL for: apha.dk and: www.apha.dk
[12.08.2022_07-38-33] Trying to obtain SSL for: apha.dk
[12.08.2022_07-38-34] Failed to obtain SSL, issuing self-signed SSL for: apha.dk
[12.08.2022_07-38-35] Self signed SSL issued for apha.dk.
I have Cyberpanel 2.3 build 2 installed.
Any ideas how to make CyberPanel use the Lets Encrypt certificate instead?
Hello @aphandersen Happy you are here
When you reach this part in the wiki you can skip these steps:
Then you delete all private keys and certificates for respective website from server:
Then run this command from [How to fix SSL issues in CyberPanel]
(https://community.cyberpanel.net/t/how-to-fix-ssl-issues-in-cyberpanel/90#debugging-with-command-line-6)
And run this script:
sh <(curl https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/selfsigned_fixer.sh || wget -O - https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/selfsigned_fixer.sh)
See wiki after skipping those parts and proceed to this part:
Then Go back to OLS and add the privatekey /etc/letsencrypt/live/mydomain.com/privkey.pem and fullchain /etc/letsencrypt/live/mydomain.com/fullchain.pem links to the vHost of the domain
Hi, thank you for your help :slight_smile: However, it still didn’t work :frowning:
In the OLS WebAdmin Console the Private key file and Certificate file is set to correct Lets Encrypt destinations. I runned your tool, but it didn’t change anything. I still have the selfsigned SSL certificate on apha.dk
Did you delete the values on OLS and restart lsws before you begun. And also restarted after you were done ?
  1. KIndly upgrade your copy and also run wget -O - https://get.acme.sh | sh
  2. Fix folder permissions for that domain How to fix SSL issues in CyberPanel - Docs - CyberPanel Community
  3. Check modsecurity How to fix SSL issues in CyberPanel - Docs - CyberPanel Community
  4. confirm you have the /usr/local/lsws/Example/html/.well-known/acme-challenge folder and /.well-known/acme-challenge context How to fix SSL issues in CyberPanel - Docs - CyberPanel Community
  5. Delete all ssl files for alpha.dk (optional script will do this for you) and OLS records (a must)
FInally retry CyberPanel Self-signed SSL certificate - #2 by josephgodwinke
Arh missed that. I have done that now. Now Lets Encrypt is named on the certificate when I visit the website, but I still get a warning. If I look on the certificate, it doesn’t say the URL apha.dk, but instead the URL of my CyberPanel. It is also the date from yesterday when I added the domain, even though I have tried to
SSL
I have also tried from point 1-4. How do I do point 5, deleting the certificates? Is this just deleting the two .pem files?
I have checked your domain its perfect except for mismatch.
Go to OLS WebAdmin COnsole under Virtual Hosts choose apha.dk confirm you have the correct paths for /etc/letsencrypt/live/apha.dk/privkey.pem and fullchain /etc/letsencrypt/live/apha.dk/fullchain.pem
The Common name: should be apha.dk and SANs: apha.dk, www.apha.dk in chained certificate
NOT Common name: panel.ansico.dk and SANs: panel.ansico.dk
I forgot to correct from mydomain.com to apha.dk in the certificate file line, I have corrected that now. But now the Dis certificate is back
My OLS Admin looks like this:
Hello you have undone your perfect changes.
Kindly follow the instructions as written here and nowhere else (copy paste as is):
Go to OLS WebAdmin Console of your server i.e https://SERVER_URL:7080 use admin and password you chose for CyberPanel admin panel
If you cannot log in. Using SSH Terminal run adminPass add new password
ols
$ rm -f /etc/letsencrypt/live/apha.dk/privkey.pem && rm -f /etc/letsencrypt/live/apha.dk/fullchain.pem
Then run this command:
$ /root/.acme.sh/acme.sh --issue -d apha.dk -d www.apha.dk --cert-file /etc/letsencrypt/live/apha.dk/cert.pem --key-file /etc/letsencrypt/live/apha.dk/privkey.pem --fullchain-file /etc/letsencrypt/live/apha.dk/fullchain.pem -w /usr/local/lsws/Example/html --force --debug
Post screenshot of your terminal after above command
Go back to OLS and add the privatekey /etc/letsencrypt/live/apha.dk/privkey.pem and fullchain /etc/letsencrypt/live/apha.dk/fullchain.pem links to the vHost of the domain
ols
Here is the output after running the code:
root@ansicoCyberPanel:~# rm -f /etc/letsencrypt/live/apha.dk/privkey.pem && rm -f /etc/letsencrypt/live/apha.dk/fullchain.pem
root@ansicoCyberPanel:~# /root/.acme.sh/acme.sh --issue -d apha.dk -d www.apha.dk --cert-file /etc/letsencrypt/live/apha.dk/cert.pem --key-file /etc/letsencrypt/live/apha.dk/privkey.pem --fullchain-file /etc/letsencrypt/live/apha.dk/fullchain.pem -w /usr/local/lsws/Example/html --force --debug
[Thu 08 Dec 2022 12:23:39 PM UTC] Lets find script dir.
[Thu 08 Dec 2022 12:23:39 PM UTC] _SCRIPT_='/root/.acme.sh/acme.sh'
[Thu 08 Dec 2022 12:23:39 PM UTC] _script='/root/.acme.sh/acme.sh'
[Thu 08 Dec 2022 12:23:39 PM UTC] _script_home='/root/.acme.sh'
[Thu 08 Dec 2022 12:23:39 PM UTC] Using config home:/root/.acme.sh
https://github.com/acmesh-official/acme.sh
v3.0.5
[Thu 08 Dec 2022 12:23:39 PM UTC] Running cmd: issue
[Thu 08 Dec 2022 12:23:39 PM UTC] _main_domain='apha.dk'
[Thu 08 Dec 2022 12:23:39 PM UTC] _alt_domains='www.apha.dk'
[Thu 08 Dec 2022 12:23:39 PM UTC] default_acme_server='https://acme-v02.api.letsencrypt.org/directory'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Thu 08 Dec 2022 12:23:39 PM UTC] DOMAIN_PATH='/root/.acme.sh/apha.dk'
[Thu 08 Dec 2022 12:23:39 PM UTC] Le_NextRenewTime
[Thu 08 Dec 2022 12:23:39 PM UTC] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
[Thu 08 Dec 2022 12:23:39 PM UTC] _init api for server: https://acme-v02.api.letsencrypt.org/directory
[Thu 08 Dec 2022 12:23:39 PM UTC] GET
[Thu 08 Dec 2022 12:23:39 PM UTC] url='https://acme-v02.api.letsencrypt.org/directory'
[Thu 08 Dec 2022 12:23:39 PM UTC] timeout=
[Thu 08 Dec 2022 12:23:39 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Thu 08 Dec 2022 12:23:39 PM UTC] ret='0'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_NEW_AUTHZ
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
[Thu 08 Dec 2022 12:23:39 PM UTC] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf'
[Thu 08 Dec 2022 12:23:40 PM UTC] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Thu 08 Dec 2022 12:23:40 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Thu 08 Dec 2022 12:23:40 PM UTC] _on_before_issue
[Thu 08 Dec 2022 12:23:40 PM UTC] _chk_main_domain='apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] _chk_alt_domains='www.apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] Le_LocalAddress
[Thu 08 Dec 2022 12:23:40 PM UTC] d='apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] Check for domain='apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Thu 08 Dec 2022 12:23:40 PM UTC] d='www.apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] Check for domain='www.apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] _saved_account_key_hash is not changed, skip register account.
[Thu 08 Dec 2022 12:23:40 PM UTC] Read key length:2048
[Thu 08 Dec 2022 12:23:40 PM UTC] _createcsr
[Thu 08 Dec 2022 12:23:40 PM UTC] Multi domain='DNS:apha.dk,DNS:www.apha.dk'
[Thu 08 Dec 2022 12:23:40 PM UTC] Getting domain auth token for each domain
[Thu 08 Dec 2022 12:23:40 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Thu 08 Dec 2022 12:23:40 PM UTC] payload='{"identifiers": [{"type":"dns","value":"apha.dk"},{"type":"dns","value":"www.apha.dk"}]}'
[Thu 08 Dec 2022 12:23:40 PM UTC] RSA key
[Thu 08 Dec 2022 12:23:40 PM UTC] HEAD
[Thu 08 Dec 2022 12:23:40 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Thu 08 Dec 2022 12:23:40 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g  -I  '
[Thu 08 Dec 2022 12:23:40 PM UTC] _ret='0'
[Thu 08 Dec 2022 12:23:40 PM UTC] POST
[Thu 08 Dec 2022 12:23:40 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Thu 08 Dec 2022 12:23:40 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Thu 08 Dec 2022 12:23:41 PM UTC] _ret='0'
[Thu 08 Dec 2022 12:23:41 PM UTC] code='429'
[Thu 08 Dec 2022 12:23:41 PM UTC] Le_LinkOrder
[Thu 08 Dec 2022 12:23:41 PM UTC] Le_OrderFinalize
[Thu 08 Dec 2022 12:23:41 PM UTC] Create new order error. Le_OrderFinalize not found. {
  "type": "urn:ietf:params:acme:error:rateLimited",
  "detail": "Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: apha.dk,www.apha.dk, retry after 2022-12-09T05:34:48Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/",
  "status": 429
[Thu 08 Dec 2022 12:23:41 PM UTC] pid
[Thu 08 Dec 2022 12:23:41 PM UTC] No need to restore nginx, skip.
[Thu 08 Dec 2022 12:23:41 PM UTC] _clearupdns
[Thu 08 Dec 2022 12:23:41 PM UTC] dns_entries
[Thu 08 Dec 2022 12:23:41 PM UTC] skip dns.
[Thu 08 Dec 2022 12:23:41 PM UTC] _on_issue_err
[Thu 08 Dec 2022 12:23:41 PM UTC] Please add '--debug' or '--log' to check more details.
[Thu 08 Dec 2022 12:23:41 PM UTC] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[Thu 08 Dec 2022 12:23:41 PM UTC] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1f  31 Mar 2020
apache:
apache doesn't exist.
nginx:
nginx doesn't exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.3 on Oct 26 2019 17:42:04
   running on Linux version #123-Ubuntu SMP Fri Apr 8 09:10:54 UTC 2022, release 5.4.0-109-generic, machine x86_64
features:
  #define WITH_STDIO 1
  #define WITH_FDNUM 1
  #define WITH_FILE 1
  #define WITH_CREAT 1
  #define WITH_GOPEN 1
  #define WITH_TERMIOS 1
  #define WITH_PIPE 1
  #define WITH_UNIX 1
  #define WITH_ABSTRACT_UNIXSOCKET 1
  #define WITH_IP4 1
  #define WITH_IP6 1
  #define WITH_RAWIP 1
  #define WITH_GENERICSOCKET 1
  #define WITH_INTERFACE 1
  #define WITH_TCP 1
  #define WITH_UDP 1
  #define WITH_SCTP 1
  #define WITH_LISTEN 1
  #define WITH_SOCKS4 1
  #define WITH_SOCKS4A 1
  #define WITH_PROXY 1
  #define WITH_SYSTEM 1
  #define WITH_EXEC 1
  #undef WITH_READLINE
  #define WITH_TUN 1
  #define WITH_PTY 1
  #define WITH_OPENSSL 1
  #undef WITH_FIPS
  #define WITH_LIBWRAP 1
  #define WITH_SYCLS 1
  #define WITH_FILAN 1
  #define WITH_RETRY 1
  #define WITH_MSGLEVEL 0 /*debug*/
And here is a screenshot of OLS admin after adding the file paths again:
Check your DNS records. YOu do not have rDNS PTR record. Go to your digital ocean dashboard and create one for your server
DO you have hostname certificate?
https://159.223.208.216/ No certificate.
Certificate error: RemoteCertificateNameMismatch
What are rDNS PTR records used for? Isn’t that only for secure mail, because I use Sendgrid af mailrelay, so they should handle that part.
Yes I have a hostname certificate on the subdomain that I use to access the panel.
Unfortunately I can see that I have now tried to renew the Lets Encrypt certificate 5 times, and unfortunately deleted the old ones, so I guess I have to wait a week before I try again :slight_smile:
Just a follow up on this, since I have now found a solution that works for me. I first created a free ZeroSSL certificate on zerossl.com. The content of the files certificate, ca_bundle and private I pasted in the fields at Add SSL in CyberPanel. The ZeroSSL certificate was installed instead. After that I go back to CyberPanel and issued a new Lets Encrypt certificate, and this time it was installed perfectly and overwrite the ZeroSSL certificate.
Did you solve your issue?
Yes I did :slightly_smiling_face:
