[Tutorial] How to setup and login to OpenLiteSpeed webadmin console
in Cyberpanel, some advanced configuration needs to be done in OLS webadmin console.
how to:
first , run this line in SSH to setup login info for webadmin console
/usr/local/lsws/admin/misc/admpass.sh
and then, login into CyberPanel , and add TCP 7080 port to firewalld in order to access it.
and please don’t forget to reload the firewalld once new rule is added.
after that , you can know access it by https://Server-IP:7080
and with the login info you set in SSH.
the console itself currently comes with Chinese, English and Japanese.
of course , anyone who wishes to translate to his/her language is more than welcome :slight_smile:
original posted here by myself , and translated by myself
OLS web adm panel looks pretty concise, and this advantage can be integrated into CyberPanel. Why the panel leaves this untouched and hasn’t had it connected? I previously thought the web server section/module inside the panel is ‘outsourced’ to OLS web admin panel.
OLS supports different distros while Cyber cannot. What a pity.
there is docker image now , you can try on other distros.
This guide works, but SSL/Certificate is invalid on port 7080, How to fix this?
I’m using a hostname for cyberpanel with valid cert.
cert file is under /usr/local/lsws/admin/conf/ , webadmin.crt and webadmin.key
either replace these 2 with your current cert , or change its path in webadmin console.
I’m using the built-in Free LetsEncrypt Cert.
Replacing or moving it will fail auto renew I think.
I mean change this to /usr/local/lsws/conf/vhosts/SSL-domain/fullchain.pem and private key
Solved, thanks!
Please include this on future update.
Hello
I can´t make the SSL work in :7080 ;(
in the webadmin settings i have:
PRIVATE KEY : /etc/letsencrypt/live/MYDOMAIN.com/privkey.pem
CERTIFICATE FILE: /etc/letsencrypt/live/MYDOMAIN.com/fullchain.pem
both are the correct SSL for the domain.
But when i go to https://MYDOMAIN.com:7080 i get “invalid SSL”
always appears the certificate of webadmin…
Thanks for any help.
Fabian
;( i found it …
was in another section… i put the paths:
and now… i can´t logn anymore in the webadmin ;(
F.
well apparenty i broke something ;(
cyberpanel is ON and i can login to :8090
BUt litespeed is DOwn
I can´t restart it in any way
“Could not fetch details, either LiteSpeed is not running or some error occurred, please see CyberPanel Main log file.”
when i press in “LIcence Status” i got:
Operation Failed!
Command ‘[‘sudo’, ‘cat’, ‘/usr/local/lsws/conf/serial.no’]’ returned non-zero exit status 1
All was working perfect! ;( not nothing works…
I would appreciate any help
Thanks
Fabian
was my mistake !!! after 2 hours… I FIXED !!!
was a very stupid mistake…
i write here as example: “/etc/letsencrypt/live/MYDOMAIN.com/privkey.pem”
and i put exactly that in the webadmin… and “MYDOMAIN.com” was the problem
i fixed it from ssh, restarted LS and all is working like a charme now… including the webadmin at :7080 with SSL
Regards and sorry for the previous posts :wink:
Thanks
Fabian
https://my.domain-or-ip:7080
But in the browser it remains “Connecting…” Any idea?
It never connects me. Something like how much the web server is stopped that does not release error but stays connected. But in this case the web server is working normally.
[SOLVED]
Solution: Open port 7080 in CyberPanel Firewall
Followed the instructions above, but now litespeed won’t start.
The error log reads as follows:
2019-09-04 17:21:21.690291 [INFO] [Module: modcompress 1.1] has been initialized successfully
2019-09-04 17:21:21.690397 [INFO] [Module: moddecompress 1.1] has been initialized successfully
2019-09-04 17:21:21.690470 [INFO] [Module: cache 1.61] has been initialized successfully
2019-09-04 17:21:21.690535 [INFO] [Module: mod_security Mod_Security 1.1] has been initialized successfully
2019-09-04 17:21:21.690590 [ERROR] [SSL] Config SSL Context with Certificate File: /usr/local/lsws/usr/local/lsws/admin/conf/webadmin.crt and Key File:/usr/local/lsws/usr/local/lsws/admin/conf/webadmin.key get SSL error:
2019-09-04 17:21:21.690597 [ERROR] [config:admin:listener:adminListener:ssl] failed to create new SSLContext for *:7080
2019-09-04 17:21:21.690602 [ERROR] [config:admin:listener] No listener is available for admin virtual host!
2019-09-04 17:21:21.690614 [ERROR] Fatal error in configuration, exit!
The error seems to be in the line where it’s looking for the cert and key file in /usr/local/lsws/usr/local/lsws/admin/conf
I can SSH into the server. Any suggestions on where to find the config file to edit, and what the correct values should be?
I was able to undo the damage. In case anyone else shares the same fate, the solution is that the config file is located at /usr/local/lsws/admin/conf/admin_config.conf
This should be setup by default going forward for both OLS and LS admin after this commit is merged into the installer. When issuing hostname SSL it should also cover either OLS/LS admin area SSL now with the same certificate via symlink.
If you want to do this manually until then without having to do it via the webadmin settings it can easily be done via the below commands.
LSWebadmin
mv /usr/local/lsws/admin/conf/cert/admin.crt /usr/local/lsws/admin/conf/cert/admin.crt-bak
mv /usr/local/lsws/admin/conf/cert/admin.key /usr/local/lsws/admin/conf/cert/admin.key-bk
ln -s /usr/local/lscp/conf/cert.pem /usr/local/lsws/admin/conf/cert/admin.crt
ln -s /usr/local/lscp/conf/key.pem /usr/local/lsws/admin/conf/cert/admin.key
OLS webadmin
mv /usr/local/lsws/admin/conf/webadmin.crt /usr/local/lsws/admin/conf/webadmin.crt-bak
mv /usr/local/lsws/admin/conf/webadmin.key /usr/local/lsws/admin/conf/webadmin.key-bk
ln -s /usr/local/lscp/conf/cert.pem /usr/local/lsws/admin/conf/webadmin.crt
ln -s /usr/local/lscp/conf/key.pem /usr/local/lsws/admin/conf/webadmin.key
restart lsws/ols
service lsws restart
The webadmin functions do not work:
How to add to cyberpanel what is described here:
https://www.litespeedtech.com/support/wiki/doku.php/litespeed_wiki:config:cloudflare-ips-or-subnets
if your accessing the LSW web admin over port 8090 behind CF its going to fail to load stuff. You need to use the IP:8090 vs the hostname or domain if its behind CF as port 8090 is NOT supported by CF.
You misunderstood. If I have unblocked port 8090 to login in: https://ip:8090, websites that are supported by cloudflare will stop working. They will show error 522.
For them to work, I need to block port 8090 but then I can’t use the cyberpanel because without the port unblocked I won’t be able to access it.
i am curious about this, i am using cloudflare with no issues. I gray cloud my cyberpanel address https://ip:8090 and the rest is running with orange cloud no issues.
