Getting this from the error logs when I try to start Open LiteSpeed:
2019-09-04 18:14:06.999819 [ERROR] [SSL] Config SSL Context with Certificate File: /usr/local/lsws/usr/local/lsws/admin/conf/webadmin.crt and Key File:/usr/local/lsws/usr/local/lsws/admin/conf/webadmin.key get SSL error:
2019-09-04 18:14:06.999825 [ERROR] [config:admin:listener:adminListener:ssl] failed to create new SSLContext for *:7080
2019-09-04 18:14:06.999830 [ERROR] [config:admin:listener] No listener is available for admin virtual host!
2019-09-04 18:14:06.999846 [ERROR] Fatal error in configuration, exit!
I had followed a tutorial about changing the path of the private key file and certificate in the WebAdmin Settings of OSL, and after performing a graceful restart, OSL won’t start. Here’s the tutorial in question:
Any suggestions as to what file I can edit to get OSL working again?
