does cyberpanel integrate with whmcs for adding servers?
you mean same function as virtualizor ?
No like plesk or cpanel?
However if it could eventually work like virtualizor or virtuosso, it would be great since I want to keep our solution to litespeed, cyberpanel, cloudlinux , whmcs as much as possible.
I use this without any problem do you have any question?
do you have a recommended ami from aws for install?
it depends on what exactly you want to start with
please note I prefer virtualizor usage with dedicated as it have some issues when use with cloud
do you want host your own websites or making vps’s for a client or … ? many scenarios
Not many but a combination of the two.
What I need immediate help with is:
I am installing the lightspeed technologies ami for cyberpanel on AWS (no problems)
I need to install or get WHMCS working asap
Convert OS to cloudlinux.
Next phase:
Take a new look at either virtualizor or virtuozzo
Reading on the cyberpanel. Vs your own solution for high availability, etc
Reading up right now on cloud.cyberpanel.com will activate the moment I get whmcs running
Louis Sanchez
312-450-2260
https://www.sanfamfoundation.com
1- Great
2- WHMCS Did you try this steps ?
3- convert to cloudlinux is very easy if you follow steps of usmannasir Here >> https://community.cyberpanel.net/t/1-convert-cyberpanel-to-cloudlinux-os-and-install-cagefs/174
5- Virtualizor or any other option is different as cyberpanel is CP but it have option such as VMM https://cyberpanel.net/docs/rc-installing-cyberpanel-vmm-virtual-machine-manager/
6- for high availability, I recommend use cyberpanel cloud as it’s more easy for you, there is another options but you need experience … please not I’m just member same as you and just help others using my experience ![]()
7- yes sure cloud will help you much
