Using WHMCS module for CyberPanel, you can sell or automate basic functions of CyberPanel for your customers. You can install this module by following WHMCS server module installation steps. Here they are again:-
Great work Jetchirag! Thanks for improving it further! We would appreciate it a lot if we can also choose the ACL or max website with the module. As now API supports both I believe
API doesn’t support this yet. There is an issue if any website failed to terminate automatically it shows in the whmcs pending action menu and when you retry the action it shows success but the website still remain. We have to manually remove the site.
@mazeweb You have to upload these files in modules/servers/cyberpanel not in webroot. You can then add a new server for cyberpanel like usual in WHMCS.
Great addon, Just tested it, Creates the account no problem, But doesnt seem to suspend the account or terminate. it changes the whmcs status to suspend and terminate, But it doesnt suspend nor terminate via CyberPanel
This is my first post here. Thanks, jetchirag for the module.
I have installed the module and set everything up on my server and WHMCS, including creating a special user, assigning an ACL and enabling API Access, but like @usamayounus, I cannot find an “Access Hash” anywhere. Is this the SSH key?
Any help with this will be greatly appreciated. Thank you!
you don’t need any “Access Hash” simply use your API user id normally “admin” or your reseller id with API permission & it’s password, you may be get “unknown error” just ignore it & continue rest of the setup. You are done.
