but when I visit the site, it’s not working and here is the SSLshopper check result:
The certificate was issued by Let’s Encrypt.
The certificate will expire in 89 days.
None of the common names in the certificate match the name that was entered (alternatively.com). You may receive an error when accessing this site in a web browser. Learn more about name mismatch errors.
@usmannasir
I’m also facing the same issue.
I tried all mentioned steps and troubleshooted everything but SSL still does not work
I was working fine till 23/07/2021. Stopped working after that
It says
HAS SELF-SIGNED SSL.
Your SSL will expire in 3649 days.
me too
then i got LE limits 5/7 (because i change the IN A and revoke and re create (test) at other server)
then i tried go to other SSL and manually upload the cert and private key to ssl path
and it solved…
custom SSL:
Website–> Add SSL
paste your : certificate.crt under “paste your cert”
priv.key under “paste your key”
then at the same place
give one “enter”
then paste bundled crt under priv.key
better if you know the DNS for IN CAA from your certificate publisher
fyi: LE SSL is only issue 4-5 cert for same domain name for 7-10 days
via CF 5 times for 7 days
if you already reach the limit of issue certificate, then the wizazrd will end with error
if your website is empty site you can push the https using rewrite rule
To replace a demo SSL with a production wildcard certificate from DigiCert, start by logging into CertCentral and ensuring your domain is fully validated. Then, go to Certificates > Request a Certificate, and choose the Wildcard SSL option under your production CA. Submit the CSR and complete any required validations. Once the certificate is issued, download it in the format needed for your server (e.g., Apache, NGINX). Replace the demo certificate with the new one on your server and restart your web service to apply the change.
