How do i get a valid cloudfare ssl for my website?
I tried getting a certificate from Cloudfare instead of Let’s Encrypt,
On my Manage section on Cyberpanel it is showing as
"… HAS SSL FROM CLOUDFLARE, INC…
Your SSL will expire in 5474 days."
But when i open my website in new tab, by using preview button it is still showing unsecure.
Plus i tried checking it on ssl checker, following error is shown -
The certificate is not trusted in all web browsers. You may need to install an Intermediate/chain certificate to link it to a trusted root certificate. [Learn more about this error]. The fastest way to fix this problem is to contact your SSL provider.
Password problem is solved. I have deleted private keys and cert at virtual host level. I tried deleted private keys and cert for website by using command you provided.
It is showing= -bash: $: command not found (For all the 3 commands). Shall i proceed to next step?
okay will it show any result? like i ran them line by line by adding my domain in the command. but when i enter. it just shows next line of command starting with #
