Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Package ‘pure-ftpd’ is not installed, so not removed
rm: cannot remove ‘/etc/pure-ftpd’: No such file or directory
failed
Yes rerun it on another server and got that error cause its supposed to stop if anything fails. Just added conditions however you can just run the commands here as i try to improve it for everyone
after these steps, i cheked pure-ftpd status and looks like works correctly, but when i try to login from filezilla:
when generated new one pure-ftpd.pem file:
openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
error:
00:21:08 Status: Resolving address of example.com
00:21:08 Status: Connecting to xx.xx.xxx.xxx:21…
00:21:08 Status: Connection attempt failed with “ECONNREFUSED - Connection refused by server”.
00:21:08 Error: Could not connect to server
when i used original pure-ftpd.pem file after Cyber Panel installation:
error:
Host: example.com:21 hostname does not match certificate
Did you ever figure this out? I am having the exact same issue. Running Cyperpanel 2.3 on a Vultr instance with Ubuntu 20.04 LTS x64 and the FTP account I create does not work. How can I test if my issue i also caused by pure-ftpd?
PS: I ran some commands I found in this and another thread and this is the output I got:
