FTP not working - 530 Login authentication failed
I installed a fresh copy of Ubuntu 22.04 and installed the CyberPanel. I created a website and I added an ftp account. But when I try to login with my ftp information I am getting error message, “530 Login authentication failed”. I checked to make sure, my user name and password is correct. I also have these following ports open for TCP, 21-22, 40000-50000 and 990.
I don’t know what I am doing wrong here… So I created a test server at this URL
https://193.122.135.18:8090/. The username and password is the default. I am still getting the same error message on the test server also.
Please help you out here.
Thank you!
Welcome @savors.map Happy you are here
530 Login authentication failed occurs when you are using either a wrong username, password, port or hostname
Go to https://SERVER_URL:8090/ftp/listFTPAccounts change password and confirm username
I see you are using FIleZilla - a crude workaround is go to the settings in the “Encryption” section and set “Use simple FTP” .
Also try another client see if you will find any success
I know it is not wrong password because I have tried different passwords and am getting the same error message. I also tried using “Only use Plain FTP” in FileZilla and it doesn’t work. I also tried to connect to the ftp server through the command prompt and I am getting the same error message.
ftpDOSError01
Post the contents of https://SERVER_IP:8090/serverlogs/ftplogs
You can login to the server and take a look directly.
https://193.122.135.18:8090/serverlogs/ftplogs
username : admin
password: 1234567
I recommend we reinstall it seems like password db is corrupt. Which os is this?
The OS is UBUNTU 22.04. This is a fresh install. The same error happened on my previous fresh install. So I ran up another server and installed in brand new on the new server. And I got the same error message on both the servers.
Seems to be reoccuring on almost all new installations. However, the only way to fix this is reinstall pureftpd or install CyberPanel without ftp.
Run this to remove pure-ftpd software package and reinstall it again just to eliminate any package and conf corruptions:
# create a snapshot of your server
# stop the service
systemctl stop pure-ftpd
# remove package and leftovers
sudo apt-get purge --auto-remove pure-ftpd
sudo apt install pure-ftpd -y
groupadd -g 2001 ftpgroup
useradd -u 2001 -s /bin/false -d /bin/null -c "pureftpd user" -g ftpgroup ftpuser
systemctl start pure-ftpd
mkdir /etc/ssl/private
openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj "/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com" -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
rm -R /etc/pure-ftpd
mkdir /etc/pure-ftpd
cp /usr/local/CyberCP/install/pure-ftpd-one/* /etc/pure-ftpd/
systemctl restart pure-ftpd
If you get an error that Access denied for user ('cyberpanel' @ 'localhost' ... run the following command nano pureftpd-mysql.conf and change the password to correct cyberpanel user password you can find it here /usr/local/CyberCP/CyberCP/settings.py under DATABASES =
I ran all those commands and I am getting follow error message.
I rebooted the entire machine. Now the FTP service is not running and I am not able to connect to the server.
What is the results of
$ journalctl -u pure-ftpd --no-pager |sed -e "s|$(hostname)|hostname|g"
Try run
systemctl start pure-ftpd.service
I ran both the commands and this is what I am getting.
Kindly just copy paste the following commands:
# on new line <= this is just a comment to guide you
systemctl status pure-ftpd.service
and copy paste the results here not screenshot
Not really fix but use SFTP by creating on site manager SSH account for site. That will be much more secure option than FTP.
ubuntu@instance-test:~$ journalctl -u pure-ftpd --no-pager |sed -e “s|$(hostname)|hostname|g”
Dec 13 06:22:29 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:22:30 hostname pure-ftpd[12185]: Starting ftp server:
Dec 13 06:22:30 hostname pure-ftpd[12193]: Running: /usr/sbin/pure-ftpd -p 40110:40210 -A -P 193.122.135.18 -Y 1 -B
Dec 13 06:22:30 hostname systemd[1]: Started pure-ftpd.service.
Dec 13 06:25:06 hostname systemd[1]: Stopping pure-ftpd.service…
Dec 13 06:25:06 hostname pure-ftpd[12354]: Stopping ftp server: pure-ftpd.
Dec 13 06:25:06 hostname systemd[1]: pure-ftpd.service: Deactivated successfully.
Dec 13 06:25:06 hostname systemd[1]: Stopped pure-ftpd.service.
Dec 13 06:25:06 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:25:06 hostname pure-ftpd[12364]: Starting ftp server:
Dec 13 06:25:06 hostname pure-ftpd[12372]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:25:06 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:25:06 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:25:06 hostname systemd[1]: Failed to start pure-ftpd.service.
– Boot 47dd6ab6a8b34dbe96e766f59aead0c4 –
Dec 13 06:26:24 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:26:26 hostname pure-ftpd[1067]: Starting ftp server:
Dec 13 06:26:26 hostname pure-ftpd[1095]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:26:26 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:26:26 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:26:26 hostname systemd[1]: Failed to start pure-ftpd.service.
Dec 13 06:27:50 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:27:51 hostname pure-ftpd[1763]: Starting ftp server:
Dec 13 06:27:51 hostname pure-ftpd[1771]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:27:51 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:27:51 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:27:51 hostname systemd[1]: Failed to start pure-ftpd.service.
– Boot 0366046163bf4a37b650ef403c8658b7 –
Dec 13 06:29:06 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:29:07 hostname pure-ftpd[1001]: Starting ftp server:
Dec 13 06:29:07 hostname pure-ftpd[1020]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:29:07 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:29:07 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:29:07 hostname systemd[1]: Failed to start pure-ftpd.service.
– Boot f6e348b90da94adeaf7cfbbb927e1eb6 –
Dec 13 06:36:14 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:36:16 hostname pure-ftpd[1067]: Starting ftp server:
Dec 13 06:36:16 hostname pure-ftpd[1103]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:36:16 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:36:16 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:36:16 hostname systemd[1]: Failed to start pure-ftpd.service.
Dec 13 06:42:19 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:42:19 hostname pure-ftpd[2696]: Starting ftp server:
Dec 13 06:42:19 hostname pure-ftpd[2706]: Running: /usr/sbin/pure-ftpd -l pam -O clf:/var/log/pure-ftpd/transfer.log -u 1000 -J HIGH -E -B
Dec 13 06:42:19 hostname systemd[1]: Started pure-ftpd.service.
Dec 13 06:44:45 hostname systemd[1]: Stopping pure-ftpd.service…
Dec 13 06:44:45 hostname pure-ftpd[2847]: Stopping ftp server: pure-ftpd.
Dec 13 06:44:45 hostname systemd[1]: pure-ftpd.service: Deactivated successfully.
Dec 13 06:44:45 hostname systemd[1]: Stopped pure-ftpd.service.
Dec 13 06:44:45 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:44:45 hostname pure-ftpd[2857]: Starting ftp server:
Dec 13 06:44:45 hostname pure-ftpd[2865]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:44:45 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:44:45 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:44:45 hostname systemd[1]: Failed to start pure-ftpd.service.
– Boot 793462e16b7c43b0adfc58496aa14b5d –
Dec 13 06:48:39 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:48:40 hostname pure-ftpd[1048]: Starting ftp server:
Dec 13 06:48:40 hostname pure-ftpd[1073]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:48:40 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:48:40 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:48:40 hostname systemd[1]: Failed to start pure-ftpd.service.
Dec 13 06:57:49 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:57:49 hostname pure-ftpd[1994]: Starting ftp server:
Dec 13 06:57:49 hostname pure-ftpd[2002]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:57:49 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:57:49 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:57:49 hostname systemd[1]: Failed to start pure-ftpd.service.
Dec 13 06:58:32 hostname systemd[1]: Starting pure-ftpd.service…
Dec 13 06:58:32 hostname pure-ftpd[2103]: Starting ftp server:
Dec 13 06:58:32 hostname pure-ftpd[2111]: /usr/sbin/pure-ftpd-wrapper: Couldn’t examine directory /etc/pure-ftpd/conf: No such file or directory
Dec 13 06:58:32 hostname systemd[1]: pure-ftpd.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Dec 13 06:58:32 hostname systemd[1]: pure-ftpd.service: Failed with result ‘exit-code’.
Dec 13 06:58:32 hostname systemd[1]: Failed to start pure-ftpd.service.
ubuntu@instance-test:~$ sudo systemctl status pure-ftpd.service
× pure-ftpd.service
Loaded: loaded (/etc/init.d/pure-ftpd; generated)
Active: failed (Result: exit-code) since Tue 2022-12-13 06:58:32 UTC; 12mi>
Docs: man:systemd-sysv-generator(8)
Process: 2103 ExecStart=/etc/init.d/pure-ftpd start (code=exited, status=2)
CPU: 85ms
Dec 13 06:58:32 instance-test systemd[1]: Starting pure-ftpd.service…
Dec 13 06:58:32 instance-test pure-ftpd[2103]: Starting ftp server:
Dec 13 06:58:32 instance-test pure-ftpd[2111]: /usr/sbin/pure-ftpd-wrapper: Cou>
Dec 13 06:58:32 instance-test systemd[1]: pure-ftpd.service: Control process ex>
Dec 13 06:58:32 instance-test systemd[1]: pure-ftpd.service: Failed with result>
Dec 13 06:58:32 instance-test systemd[1]: Failed to start pure-ftpd.service.
lines 1-13/13 (END)
Well just what i thought pure-ftpd was not fully installed. I also soemthing to indicate it here FTP not working - 530 Login authentication failed - #9 by savors.map when you creating a user for pure-ftpd.
RUn this line by line dont skip
sudo apt-get remove --purge pure-ftpd pure-ftpd-common
sudo apt autoremove
Yes. if you need to go this direction the ideal way that i have done was install cyberpanel without ftp and setup https://devanswers.co/install-ftp-server-vsftpd-ubuntu-20-04/. Works like a charm too.
ubuntu@instance-test:~$ sudo apt-get remove --purge pure-ftpd pure-ftpd-common
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following packages were automatically installed and are no longer required:
openbsd-inetd tcpd update-inetd
Use ‘sudo apt autoremove’ to remove them.
The following packages will be REMOVED:
pure-ftpd* pure-ftpd-common*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 992 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database … 127926 files and directories currently installed.)
Removing pure-ftpd (1.0.50-2.1) …
Removing pure-ftpd-common (1.0.50-2.1) …
Processing triggers for man-db (2.10.2-1) …
(Reading database … 127858 files and directories currently installed.)
Purging configuration files for pure-ftpd-common (1.0.50-2.1) …
Purging configuration files for pure-ftpd (1.0.50-2.1) …
ubuntu@instance-test:~$ sudo apt autoremove
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
After this operation, 290 kB disk space will be freed.
(Reading database … 127842 files and directories currently installed.)
Removing openbsd-inetd (0.20160825-5) …
Removing tcpd (7.6.q-31build2) …
Removing update-inetd (4.51) …
ubuntu@instance-test:~$ sudo apt install pure-ftpd -y
The following additional packages will be installed:
openbsd-inetd pure-ftpd-common tcpd update-inetd
The following NEW packages will be installed:
openbsd-inetd pure-ftpd pure-ftpd-common tcpd update-inetd
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 367 kB of archives.
After this operation, 1,282 kB of additional disk space will be used.
Get:1 Index of /ubuntu jammy/main amd64 update-inetd all 4.51 [24.9 kB]
Get:2 Index of /ubuntu jammy/universe amd64 tcpd amd64 7.6.q-31build2 [25.2 kB]
Get:3 Index of /ubuntu jammy/universe amd64 openbsd-inetd amd64 0.20160825-5 [26.3 kB]
Get:4 Index of /ubuntu jammy/universe amd64 pure-ftpd-common all 1.0.50-2.1 [148 kB]
Get:5 Index of /ubuntu jammy/universe amd64 pure-ftpd amd64 1.0.50-2.1 [143 kB]
Fetched 367 kB in 1s (456 kB/s)
Preconfiguring packages …
Can’t exec “/tmp/update-inetd.config.NhvPqD”: Permission denied at /usr/lib/x86_64-linux-gnu/perl-base/IPC/Open3.pm line 178.
open2: exec of /tmp/update-inetd.config.NhvPqD configure failed: Permission denied at /usr/share/perl5/Debconf/ConfModule.pm line 59.
Selecting previously unselected package update-inetd.
(Reading database … 127816 files and directories currently installed.)
Preparing to unpack …/update-inetd_4.51_all.deb …
Unpacking update-inetd (4.51) …
Selecting previously unselected package tcpd.
Preparing to unpack …/tcpd_7.6.q-31build2_amd64.deb …
Unpacking tcpd (7.6.q-31build2) …
Selecting previously unselected package openbsd-inetd.
Preparing to unpack …/openbsd-inetd_0.20160825-5_amd64.deb …
Unpacking openbsd-inetd (0.20160825-5) …
Selecting previously unselected package pure-ftpd-common.
Preparing to unpack …/pure-ftpd-common_1.0.50-2.1_all.deb …
Unpacking pure-ftpd-common (1.0.50-2.1) …
Selecting previously unselected package pure-ftpd.
Preparing to unpack …/pure-ftpd_1.0.50-2.1_amd64.deb …
Unpacking pure-ftpd (1.0.50-2.1) …
Setting up pure-ftpd-common (1.0.50-2.1) …
Setting up update-inetd (4.51) …
Setting up tcpd (7.6.q-31build2) …
Setting up openbsd-inetd (0.20160825-5) …
Setting up pure-ftpd (1.0.50-2.1) …
Scanning processes…
Scanning linux images…
Running kernel seems to be up-to-date.
No services need to be restarted.
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host.
ubuntu@instance-test:~$ sudo groupadd -g 2001 ftpgroup
groupadd: group ‘ftpgroup’ already exists
ubuntu@instance-test:~$ sudo useradd -u 2001 -s /bin/false -d /bin/null -c “pureftpd user” -g ftpgroup ftpuser
useradd: user ‘ftpuser’ already exists
ubuntu@instance-test:~$ sudo systemctl start pure-ftpd
ubuntu@instance-test:~$ sudo mkdir /etc/ssl/private
mkdir: cannot create directory ‘/etc/ssl/private’: File exists
ubuntu@instance-test:~$ sudo openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
ubuntu@instance-test:~$ sudo rm -R /etc/pure-ftpd
ubuntu@instance-test:~$ sudo mkdir /etc/pure-ftpd
ubuntu@instance-test:~$ sudo cp /usr/local/CyberCP/install/pure-ftpd-one/* /etc/pure-ftpd/
ubuntu@instance-test:~$ sudo systemctl restart pure-ftpd
Job for pure-ftpd.service failed because the control process exited with error code.
See “systemctl status pure-ftpd.service” and “journalctl -xeu pure-ftpd.service” for details.
× pure-ftpd.service
Active: failed (Result: exit-code) since Tue 2022-12-13 07:30:06 UTC; 44s >
Process: 4761 ExecStart=/etc/init.d/pure-ftpd start (code=exited, status=2)
CPU: 88ms
Dec 13 07:30:06 instance-test systemd[1]: Starting pure-ftpd.service…
Dec 13 07:30:06 instance-test pure-ftpd[4761]: Starting ftp server:
Dec 13 07:30:06 instance-test pure-ftpd[4769]: /usr/sbin/pure-ftpd-wrapper: Cou>
Dec 13 07:30:06 instance-test systemd[1]: pure-ftpd.service: Control process ex>
Dec 13 07:30:06 instance-test systemd[1]: pure-ftpd.service: Failed with result>
Dec 13 07:30:06 instance-test systemd[1]: Failed to start pure-ftpd.service.
lines 1-13/13 (END)
I have tried on test server it wierd because it worked previously but here is what i have done and it worked:
sudo service pure-ftpd stop
sudo apt-get autoremove pure-ftpd
sudo apt-get purge pure-ftpd
sudo rm -r /etc/pure-ftpd
COmpletely remove all traces of ftp or pureftpd from your server.
Just install vsftp for a secure ftp if you dont care about managing users on a dashboard
sh <(curl https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/install_vsftpd.sh || wget -O - https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/install_vsftpd.sh)
You will access ftp with user ftpuser and the password you create during the process. This user will access /home/
You can create other users by running:
# usercreatedoncyberP managed mydomain.com
sudo usermod -d /home/mydomain.com usercreatedoncyberP
sudo chown usercreatedoncyberP:usercreatedoncyberP /home/mydomain.com/public_html
I use this method on several servers and it works. Just used in test server and it works. Good luck
I tried to install vsftp and I got error message ftpuser already exsits. So I ran command sudo deluser --remove-home ftpuser. Then I tried to install again. But I am getting error message cannot create /etc/ssh/sshd_config: Permission denied. failed
ubuntu@instance-test:~$ sh <(curl https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/install_vsftpd.sh || wget -O - https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/install_vsftpd.sh)
100 1047 100 1047 0 0 4246 0 --:–:-- --:–:-- --:–:-- 4256
Install Very secure FTP daemon …
vsftpd
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 123 kB of archives.
After this operation, 326 kB of additional disk space will be used.
Get:1 Index of /ubuntu jammy/main amd64 vsftpd amd64 3.0.5-0ubuntu1 [123 kB]
Fetched 123 kB in 1s (210 kB/s)
Can’t exec “/tmp/vsftpd.config.IWUHne”: Permission denied at /usr/lib/x86_64-linux-gnu/perl-base/IPC/Open3.pm line 178.
open2: exec of /tmp/vsftpd.config.IWUHne configure failed: Permission denied at /usr/share/perl5/Debconf/ConfModule.pm line 59.
Selecting previously unselected package vsftpd.
(Reading database … 127830 files and directories currently installed.)
Preparing to unpack …/vsftpd_3.0.5-0ubuntu1_amd64.deb …
Unpacking vsftpd (3.0.5-0ubuntu1) …
Setting up vsftpd (3.0.5-0ubuntu1) …
Created symlink /etc/systemd/system/multi-user.target.wants/vsftpd.service → /lib/systemd/system/vsftpd.service.
Scanning processes…
adduser: The user `ftpuser’ already exists.
failed
ubuntu@instance-test:~$ sudo deluser --remove-home ftpuser
Looking for files to backup/remove …
Removing user ftpuser' ... Warning: group ftpgroup’ has no more members.
Done.
100 1047 100 1047 0 0 5694 0 --:–:-- --:–:-- --:–:-- 5721
vsftpd is already the newest version (3.0.5-0ubuntu1).
Adding user ftpuser' ... Adding new group ftpuser’ (1005) …
Adding new user ftpuser' (1005) with group ftpuser’ …
Creating home directory /home/ftpuser' ... Copying files from /etc/skel’ …
New password:
Retype new password:
passwd: password updated successfully
Changing the user information for ftpuser
Enter the new value, or press ENTER for the default
Full Name :
Room Number :
Work Phone :
Home Phone :
Other :
Is the information correct? [Y/n] Y
/dev/fd/63: 13: cannot create /etc/ssh/sshd_config: Permission denied
failed
