I am trying to import the database in VPS cyber panel using phymyadmin but its giving me following error.
I cannot import the database.
How to solve this?
How to solve this?
Hello @faheemkiani
Unfortunately, this has nothing to do with cyberpanel. There can be a number of issue causing this:
You need to check your connection, flush your dns cache and disable the above
I tried this method but still not working
Have you increased your timeout limit ?
How much should i increase the timeout limit?
I changed the timeout limit but still same
Did you check all of the above ERR_CONNECTION_REFUSED Error trying to import database sql on phpmyadmin - #2 by josephgodwinke
Is this still CentOS7?
Can you tell me how to give full privileges to a user of a database in VPS ?
I am getting this error now at terminal because i am trying to import the database using teriminal
“access denied for user ‘root’@‘localhost’ (using password yes)”
Can you guide me how to fix this?
You can check root mysql password here /usr/local/CyberCP/CyberCP/settings.py
DATABASES = {
'rootdb': {
'ENGINE': 'django.db.backends.mysql',
'NAME': 'mysql',
'USER': 'root',
'PASSWORD': 'cyberpanel',
'HOST': 'localhost',
'PORT': '',
but at terminal i did not put any password due to which i saw this error
Can you tell me how to find this folder at backend of cyberpanel?
how can i access via SSh or Terminal then reset the password?
i accessed the terminal.
can you tell me the command how to reset the mysql password?
