ClosedCyberPanel & Svelte Site
Welcome @sxroot Happy you are here
Error code 524 is cloudflare specific error. Kindly restart your server and try again.
Do you have any svelte related errors on your app? or any errors on the main log file for the website? or any error logs here https://<IP Address>:8090/serverlogs/errorLogs
Turned off cloudflare proxy for now so that error has disappeared, now i’m getting “This request takes too long to process, it is timed out by the server. If it should not be timed out, please contact administrator of this web site to increase ‘Connection Timeout’.” which i belive is error code 500? My svelte app works perfectly fine on localhost and pm2 runs it fine with zero errors just trying to get it working on cyberpanel
My vHost Config for my website looks like this
context / {
type appserver
location /home/gun.wtf/public_html
binPath /usr/bin/node
appType node
maxConns 100rewrite {
addDefaultCharset off
Which from reading the tutorial on the express.js one should be correct?
I’ve also opened port 2001 which my site is running on
Seems like a node version issue. Have you checked if your server meets the app’s system requirements
You should use PM2 to monitor and manage your nodejs based apps if you are using svelte to build a dynamic app
Using the latest version of node which i’m also using on my localhost as well, so node version wouldn’t be a issue would it?
Node version is an issue did you see this Deploy nodejs app doesn'nt work - #2 by josephgodwinke
Yes i saw that and did all the commands you had put in there, i’ve checked the cyberpanel logs and here is the log output
2022-12-21 19:26:53.069398 [INFO] [2355] [2.24.2.141:60152-Q:A6826A4D1EDF3324-8#gun.wtf] Connection idle time too long: 301 while in state: 6 watching for event: 270336, close!
2022-12-21 19:26:53.069446 [INFO] [2355] [2.24.2.141:60152-Q:A6826A4D1EDF3324-8] Content len: 0, request line: ‘GET / HTTP/1.1’
2022-12-21 19:26:53.069455 [INFO] [2355] [2.24.2.141:60152-Q:A6826A4D1EDF3324-8#gun.wtf] HttpExtConnector state: 8, request body sent: 0, response body size: -2, response body sent:0, left in buffer: 0, attempts: 0.
2022-12-21 19:26:53.069516 [INFO] [2355] [2.24.2.141:60152-Q:A6826A4D1EDF3324-8#gun.wtf] Proxy connection state: 2, watching event: 25, Request header:734, body:0, sent:0, Response header: 0, total: 0 bytes received in 301 seconds,Total processing time: 301.
What is running on port 3000? netstat -lp | grep 3000 and netstat -lp | grep 2001 OR use ss e.g. ss -ltp | grep 3000
Install PM2, setup pm2 and add your app
Change your expressjs app to port 3000 before adding your app
It’s a Svelte app not express, and i’m currently using PM2 to run the app? But i get an error saying something else is already running on port 3000 so it stops immediately after running.
Since svelte app is similar to expressjs app when it comes to deployment you need to check if a simple expressjs app runs as expected. If it does then you need to deploy svelte the proper way. If it fails check your nodejs installation
My nodejs installation should be fine, i installed it the same way you did on that post you linked
My svelte app runs fine on localhost so it should be fine running it on cyberpanel?
