CyberPanel Community
Cyberpanel Design - Error
OE
Olalekan Enoch #1
I used the cyberpanel dark theme design, and wants to change it back now i get Server Error (500) anytime i click the design bar?
how can I fix this?
MK
Mirza Khadnezar S [sick] #2
have you run upgrade cyberpanel yet ? if yes… when your last update ? just in case only need upgrade version to replace some error
OE
Olalekan Enoch #3
i just fresh install another… its not popping the error anymore now but the loading balls when saving stays laoding but it saving new theme now
RM
Rana Muhammad Usman Nasir #9
How did you solve the design 500 issue?
Clear your browser cache, I think javascript files not loaded in your browser.
MK
Mirza Khadnezar S [sick] #10
it was not solved
it still cannot apply
if browser cache, i always set clear cookied,cache,image,history from my browser.
and nothing change…
so this is irrelevant
but actually before that everything is working… i try all…
i got 500 error when i change it too fast…
apply then change again and apply again
then 500 error
after several minuetes
i try again, i dont get 500error
but i cant apply… the pulldown menu working. the list is there
but after apply, it’s back to empty
i already try to put manual css
still same
apply…then empty
MK
Mirza Khadnezar S [sick] #13
[03.20.2022_15-32-59] Expecting value: line 1 column 1 (char 0)
[03.20.2022_15-35-12] Expecting value: line 1 column 1 (char 0)
[03.20.2022_15-36-42] Expecting value: line 1 column 1 (char 0)
[03.20.2022_15-36-53] Expecting value: line 1 column 1 (char 0)
[03.20.2022_15-36-58] Expecting value: line 1 column 1 (char 0)
[03.20.2022_15-38-04] Expecting value: line 1 column 1 (char 0)
22-03-20_22-38-55-Cyberpanel_Design_Error
Ma
Master3395 #14
Perhaps CP should have a setting where you either SSH in or use FTP to disable “designs” in order to resolve the 500 issues.
And or have a setting to set it back to “Default” design.
But did you run the upgrader to see if design changes would work?
Also, you show your IP in the top left corner of CyberPanel. (I also think the IP should be under “version” instead of public shown.
Makes people more willing to make tutorials where they don’t have to show the IP.
But yeah story for another post another place.
MK
Mirza Khadnezar S [sick] #15
yeah . but this is another story :smiley:
yes. i run upgrade script… and 500 eror is gone.
but… i cant apply the selected skin…
RM
Rana Muhammad Usman Nasir #16
cd /usr/local/CyberCP/
source bin/activate
python manage.py dbshell
show tables;
give me output, when you run the last command.
MK
Mirza Khadnezar S [sick] #17
few second before i run
output:
MariaDB [cyberpanel]> show tables;
| Tables_in_cyberpanel                 |
| CLManager_clpackages                 |
| IncBackups_backupjob                 |
| IncBackups_incjob                    |
| IncBackups_jobsites                  |
| IncBackups_jobsnapshots              |
| auth_group                           |
| auth_group_permissions               |
| auth_permission                      |
| auth_user                            |
| auth_user_groups                     |
| auth_user_user_permissions           |
| baseTemplate_cyberpanelcosmetic      |
| baseTemplate_version                 |
| cloudAPI_wpdeployments               |
| comments                             |
| containerization_containerlimits     |
| cryptokeys                           |
| databases_databases                  |
| databases_databasesusers             |
| databases_dbmeta                     |
| databases_globaluserdb               |
| django_admin_log                     |
| django_content_type                  |
| django_migrations                    |
| django_session                       |
| dockerManager_containers             |
| domainmetadata                       |
| domains                              |
| e_domains                            |
| e_forwardings                        |
| e_transport                          |
| e_users                              |
| emailMarketing_emailjobs             |
| emailMarketing_emaillists            |
| emailMarketing_emailmarketing        |
| emailMarketing_emailsinlist          |
| emailMarketing_emailtemplate         |
| emailMarketing_smtphosts             |
| emailMarketing_validationlog         |
| emailPremium_domainlimits            |
| emailPremium_emaillimits             |
| emailPremium_emaillogs               |
| filemanager_trash                    |
| firewall_firewallrules               |
| loginSystem_acl                      |
| loginSystem_administrator            |
| mailServer_pipeprograms              |
| managePHP_apachephp                  |
| managePHP_installedpackages          |
| managePHP_installedpackagesapache    |
| managePHP_php                        |
| manageServices_pdnsstatus            |
| manageServices_slaveservers          |
| packages_package                     |
| records                              |
| s3Backups_backuplogs                 |
| s3Backups_backuplogsdo               |
| s3Backups_backuplogsminio            |
| s3Backups_backupplan                 |
| s3Backups_backupplando               |
| s3Backups_backupplanminio            |
| s3Backups_minionodes                 |
| s3Backups_websitesinplan             |
| s3Backups_websitesinplando           |
| s3Backups_websitesinplanminio        |
| supermasters                         |
| tsigkeys                             |
| users                                |
| websiteFunctions_aliasdomains        |
| websiteFunctions_backupjob           |
| websiteFunctions_backupjoblogs       |
| websiteFunctions_backups             |
| websiteFunctions_backupschedules     |
| websiteFunctions_childdomains        |
| websiteFunctions_dest                |
| websiteFunctions_gdrive              |
| websiteFunctions_gdrivejoblogs       |
| websiteFunctions_gdrivesites         |
| websiteFunctions_gitlogs             |
| websiteFunctions_normalbackupdests   |
| websiteFunctions_normalbackupjoblogs |
| websiteFunctions_normalbackupjobs    |
| websiteFunctions_normalbackupsites   |
| websiteFunctions_websites            |
84 rows in set (0.001 sec)
MK
Mirza Khadnezar S [sick] #19
try click apply click apply the design… (change all one by one… in fast…)
i have already connected to cloud…
do you need admin 8090 access ?
MK
Mirza Khadnezar S [sick] #21
still facing this problem
do you need my admin login ? (my cyberpanel still connected to cloud)
or ssh ?
MK
Mirza Khadnezar S [sick] #23
yes, i noted that. so i wish you want to take alook (if you or your team have a time ) to see whats wrong with my cyberpanel ?
MK
Mirza Khadnezar S [sick] #27
still same… default design
even i put my own css… after apply it return empty…
update at cloud
Qu
Quint #30
I have the exact same problem. Could you explain the solution or should i make a ticket?
