still facing this problem
do you need my admin login ? (my cyberpanel still connected to cloud)
or ssh ?
As I said I can not reproduce this problem on my end.
yes, i noted that. so i wish you want to take alook (if you or your team have a time ) to see whats wrong with my cyberpanel ?
still same… default design
even i put my own css… after apply it return empty…
update at cloud
yes it working…
is that something that i do make the trouble ?
I have the exact same problem. Could you explain the solution or should i make a ticket?
