Your connection is not secure
I have a problem in SSL. I have this message :
website.com HAS SELF-SIGNED SSL.
Your SSL will expire in 3649 days.
Welcome @achraf Happy you are here
You need to explain what error you are getting for us to help you. Also post a screenshot. Give us more information.
I make the Issue SSL in my cyberPanel.
But the result is this : Votre connexion is not secure
Your connection is not secure. Probably you have an expired ssl certificate, test it here SSL Server Test (Powered by Qualys SSL Labs)
https://SERVER_URL:7080
This One not working with my admin and password that I chose for CyberPanel
Run to reset OLS/LS password
cd /usr/local/lsws/admin/misc
./admpass.sh
Virtual Host Example does not exist !!
The image is just a sample you need to go to your exact Name-Based Virtual Host e.g. if your domain is myproblem.tk then go to Virtual Hosts → myproblem.tk click on the ssl tab
Yes I found it and I do everything from zero but no result
What error are you getting ? Same error ?
Yes the same error
Your connection is not private
Malicious individuals may be trying to steal your personal information from website.com (passwords, messages or credit card numbers, for example). Learn more
Check your dns zones are they correct use this tool Free DNS NS Record Lookup Tool | EasyDMARC and post the screenshot here
You should try to reissue the ssl using cyberpanel directly from 1 - Issuing SSL for website
For me I already create my websites and i make the ssl , it is worked for a while, since 15 days and today I found that my website not secure
Issue the ssl again by just clicking on issue ssl on website manager
I already did that, but the same problem
