Hi Folks,
I am facing an issue regarding my site. I have just created a new site in cyberpanel and issue SSL as well but “Your connection is private” warning is always there I wonder why? Even in chrome browser it doesn’t show the proceed button in the advance toggle however in Mozilla and other browser does show the proceed button.
What should I do to remove this warning or error (what you preferbly say this)?
One last thing is that I do understand it usually happens if anyone using IP address because it isn’t secure however it is very suspicious message that data is scrambled.
We have deployed the cyberpanel on this VM.
https://34.123.206.188/
The Server is a VM of Google Compute Engine and cyberpanel is deployed through Marketplace image.
Thanks.
Reissue your ssl and then check.
From cyberpanel you can issue from the SSL tab also share cyberpanel main logs
I had reissued the SSL certificate multiple times but it didn’t resolve my issue.
First update your panel I looked your login is old version.
You mean Cyberpanel https://34.123.206.188:8090 dont have SSL or your website?
If its panel this tutorial how to set. If its your website then check is your DNS records and if use cloudflare gray proxy cloud to see if it helps.
I have added the SSL to the hostname as well already but it didn’t work.
Here is my error logs:
2022-04-28 06:29:19.595582 [INFO] [154358] [lsphp]: locked pid file [/tmp/lshttpd/lsphp.sock.pid].
2022-04-28 06:29:19.595587 [INFO] [154358] [lsphp] remove unix socket for detached process: /tmp/lshttpd/lsphp.sock
2022-04-28 06:29:19.595636 [NOTICE] [154358] [LocalWorker::workerExec] Config[lsphp]: suExec uid 65534 gid 65534 cmd /usr/local/lsws/lsphp73/bin/lsphp, final uid 65534 gid 65534, flags: 0.
2022-04-28 06:29:19.596031 [NOTICE] [154358] [lsphp] add child process pid: 154361
2022-04-28 06:29:19.596084 [INFO] [154358] [lsphp]: unlocked pid file [/tmp/lshttpd/lsphp.sock.pid].
2022-04-28 06:29:19.596136 [INFO] [154358] [atmeg31818999.655340]: locked pid file [/tmp/lshttpd/atmeg31818999.sock.pid].
2022-04-28 06:29:19.596143 [INFO] [154358] [atmeg31818999.655340] remove unix socket for detached process: /tmp/lshttpd/atmeg31818999.sock
2022-04-28 06:29:19.596199 [NOTICE] [154358] [LocalWorker::workerExec] VHost:mail.atmega32-avr.com suExec check uid 65534 gid 65534 setuidmode 0.
2022-04-28 06:29:19.596226 [NOTICE] [154358] [LocalWorker::workerExec] Config[atmeg31818999.655340]: suExec uid 1001 gid 1002 cmd /usr/local/lsws/lsphp72/bin/lsphp, final uid 1001 gid 1002, flags: 0.
2022-04-28 06:29:19.597014 [NOTICE] [154359] LiteSpeed/1.7.12 Open
module versions:
modgzip 1.1
cache 1.62
modinspector 1.1
uploadprogress 1.1
mod_security 1.4
starts successfully!
2022-04-28 06:29:19.598159 [NOTICE] [154358] [atmeg31818999.655340] add child process pid: 154362
2022-04-28 06:29:19.598250 [INFO] [154358] [atmeg31818999.655340]: unlocked pid file [/tmp/lshttpd/atmeg31818999.sock.pid].
2022-04-28 06:29:19.598314 [NOTICE] [154358] Setup swapping space…
2022-04-28 06:29:19.601290 [NOTICE] [154358] LiteSpeed/1.7.12 Open
module versions:
modgzip 1.1
cache 1.62
modinspector 1.1
uploadprogress 1.1
mod_security 1.4
2022-04-28 06:29:19.621636 [NOTICE] [146767] New litespeed process is ready, stops listeners
2022-04-28 06:29:19.621665 [INFO] [146767] Stop all listeners.
2022-04-28 06:29:19.621675 [NOTICE] [146767] Stop listener *:80, fd 9.
2022-04-28 06:29:19.621689 [NOTICE] [146767] Stop listener *:443, fd 11.
2022-04-28 06:29:19.621713 [NOTICE] [146766] New litespeed process is ready, stops listeners
2022-04-28 06:29:19.621728 [INFO] [146766] Stop all listeners.
2022-04-28 06:29:19.621730 [NOTICE] [146767] Event-loop lingering done.
2022-04-28 06:29:19.621735 [NOTICE] [146766] Stop listener *:80, fd 8.
2022-04-28 06:29:19.621738 [NOTICE] [146767] Shut down successfully!
2022-04-28 06:29:19.621746 [NOTICE] [146766] Stop listener *:443, fd 10.
2022-04-28 06:29:19.621750 [NOTICE] [146767] HttpServerImpl::releaseAll called.
2022-04-28 06:29:19.621754 [NOTICE] [146766] Stop listener *:7080, fd 14.
2022-04-28 06:29:19.621765 [NOTICE] [146766] Event-loop lingering done.
2022-04-28 06:29:19.621769 [NOTICE] [146766] Shut down successfully!
2022-04-28 06:29:19.621778 [NOTICE] [146766] HttpServerImpl::releaseAll called.
2022-04-28 06:29:19.653184 [NOTICE] [146764] [AutoRestarter] cleanup children processes and unix sockets belong to process 146767 !
2022-04-28 06:29:19.654024 [NOTICE] [146764] [AutoRestarter] child process with pid=146767 exited with status=0!
2022-04-28 06:29:19.654073 [NOTICE] [146764] [AutoRestarter] cleanup children processes and unix sockets belong to process 146766 !
2022-04-28 06:29:19.754172 [NOTICE] [146764] [AutoRestarter] child process with pid=146766 exited with status=0!
2022-04-28 06:29:19.754272 [NOTICE] [146764] Server Stopped!
2022-04-28 06:30:19.128491 [NOTICE] [154359] [!!!UPDATE!!!] current branch new version 1.7.15.0 is available.
2022-04-28 06:30:19.128595 [NOTICE] [154359] [!!!UPDATE!!!] new stable version 1.7.15.0 is available.
Screenshot your DNS records and put here.
