Hi, i’m using Cyberpanel Ent and please do not disappoint me this small function. I tried to change my pypmyadmin upload limit but the result still with (Max: 2,048KiB)!
BUT! Phpmyadmin not must running on 7.4 or what you set on your webpage. Must in all PHP set and all restart after it (PHP 7.4, 7.3, 7.2, 7.0…). That is all…
Hi, I achieved. After increasing the PHP limits, I simply ignored the import field label. I kept waiting for the error to happen, but it didn’t. My database is over 200MB and has been successfully imported. I also read on a DEV blog that phpMyAdmin version 5.1 is not as compatible with Php 7.4. So I assumed a bug in the import field label would be the least I should expect. Good luck.
