My server use the version 2.3 Build 4
When I start the update script it runs for a while, but then I get this error message.
Any ideas?
For your information, I am still using CentOS 7, but unfortunately the support has recently expired and CentOS 7 can no longer be updated.
This is what it shows me when I search for updates for the CentOS 7 server.
I am also having the same error. Did you solve this problem?
Same problem on CloudLinux 7,
There is no more support for CentOS 7.
You can elevate to Almalinux 9.
I think the only way to get past this is to replace python3 with python 3.8 or 3.9
To fix the current panel if it’s not loading:
Follow this:
CentOS 7 has reached its end-of-life (EOL) on June 30, 2024 and is therefore no longer supported. I think it’s pointless to bother with it any further. Since Cyberpanel is now also supported by Ubuntu, I set up a new Ubuntu server and moved my web servers to it. It was a bit bumpy at first because the database was old and had accumulated junk data, but after a cleanup the migration went smoothly.
