Can you please tell me that what changes do I have to make to my existing .tgz backup file that cloudways has given me to make it work with the Vultr + Cyberpanel.
Welcome @kiltzone66058 Happy you are here
Assuming this compressed package contains only website files you can just upload the package to a CyberPanel filemanager for your website on cyberpanel. Click on Fix Permissions and see the results when you visit the domain.
Log into admin panel http://SERVER_URL:8090
On sidebar click websites → List websites (http://SERVER_URL:8090/websites/listWebsites)
On the domain you want to manage website for click Manage
On https://SERVER_URL/websites/mycoolwebsite.com (change mycoolwebsite.com to whichever website you created) and click on File Manager on the list you see
In File Manager click on Fix Permissions
No it will not you will have to do the following steps:
Go to
https://SERVER_URL:8090/dataBases/createDatabase -
Choose your website and create a database by adding a database name, username and password
Note these credentials down as these are the credentials you will add to your wp-config.php. Ask cloudways for your old website database export you will need to import it into your new database.
Go to
https://SERVER_URL:8090/phpmyadmin -
Pick your new database
Click on Import
do you see a .sql.gz or .sql anywhere in compressed backup
yes, there is a .sql file in the backup
Use it here Trying to Migrate a site from Cloudways + Vultr to Vultr + Cyberpanel - #7 by josephgodwinke
When you click import choose that file
do you mean while importing the database? and then I also have to made changes to the config.php as well right?
First update wp-config.php then import the database file. How big is the file?
the whole backup is 1.2 gb
I did those changes but the site is loading has a mobile version and only the homepage is working. Followed the all steps correctly.
All the other pages are giving 404 errors and this is how the site looks on desktop. the homepage which is only working
Did you increase the upload limit for php? that is really big 4 - Change Upload Limit for phpMyAdmin
Yes I have
Found your site you will need to log into it and change permalinks
Also check .htaccess for errors. Replace all the contents with a clean wordpress default version
