CyberPanel Community
To create a website do I need more than one nameserver?
JQ
Juan Quinta #1
Hello! Silly question
In the same panel (cyberpanel) can I create two or more name servers for different domains?
Or the new domains should only be with the first nameserver created?
1 reply
jo
josephgodwinke #2
Hello @PetzoneMx
You do not need to specify nameservers for subsequent websites you create with different domains on cyberpanel. Cyberpanel does that for you. You only need to point your domain to the correct nameservers where you purchased the domain e.g. namecheap etc.
If you are asking how many nameservers a website should have then that would be a minimum of two and a maximum of five
