Can I use the same domain for the website and email server?
At the moment my website is phonesrescue.co.uk and my email domain is mail.phonesrescue.co.uk. It makes problems with TLS certificates:
Cert VALIDATED: ok
Cert Hostname DOES NOT VERIFY (mail.phonesrescue.co.uk != phonesrescue.co.uk | DNS:phonesrescue.co.uk | DNS:www.phonesrescue.co.uk)
So email is encrypted but the host is not verified
I have my own certificates for the website and mail server, but I am not sure how to install it.
Hi Joseph,
Thank you for your response.
A wildcard certificate is much more expensive than I expected So I bought two certificates separately, for phonesrescue.co.uk and mail.phonesrescue.co.uk
I tried your solution:
Added SSL certificate from mail.phonesrescue. co.uk for mail.phonesrescue.co.uk on https:/MYCYBERPANEL/websites/phonesrescue.co.uk/mail.phonesrescue.co.uk
Restarted Postfix and Dovecot
Issues:
Error on the checktls.com:
Certificate #1 of 3 (sent by MX):
Cert VALIDATED: ok
When I try to setup SMTP on Mail App on the MacBook:
The identity of “mail.phonesrescue.co.uk” cannot be verified.
The certificate for this server is invalid.
All my sent emails are going to the spam folder.
I do not have any idea how to set up this properly. Can it be a problem with DNS? I use Cloudflare if it is any difference.
Another question: Can I insert the Chain certificate instead of Normal domain certificate in CyberPanel website settings?
