Hi all if you face errors with logging in to Rainloop and if your logs have something as “Invalid password in passdb: crypt() failed: Invalid argument” Then there is a simple fix for this. You need to update your Dovecot to 2.3.x as bcrypt is supported by 2.3.x. The steps are as follows:
Add the reposity key of dovecot to the rpm key store:
