this conversation is related to my issue, I have to update but this issue doesn’t get fixed
Mine also not fixed even after upgrade
I see, does not make sense because as per snappymail dev autocreate directive does not work anymore.
Please go through this issue and mention the issue with snappymail dev https://github.com/the-djmaze/snappymail/issues/907
We can mutually try to resolve this. If anything needed from our end, happy to help
yes, I have tried to run that run PHP script manually but that’s a temporary solution, folders are getting created for existing mail while creating new mail issue is repeating, and I can’t see any mail in the inbox
Can you refresh the mailbox once after login and see if that fix the issue?
no its not fixed issued
Hello @rohit Did you see this Redirecting...
This was the reply from SnappyMail dev, so I assume by your communication that folders are being created, but emails does not arrive in inbox?
i have tried to reinstall cyberpanel , folders get created automatically , now i cant see any mails in inbox
Did you set your MX records?
I don’t even see an MX record
Now wait for records to go through.
updated Network Tools: DNS,IP,Email but still there is email delivery issue
Check logs to see either mail is even reaching the server or not?
@usmannasir @rohit i just setup a mail on new cyberpanel after setting mail server SSL, DNS and all properly. and email sending and receiving both is working 100% fine
thanks records got updated sucessfully, now i can see mails in
