After following this guide to downgrade to openlitespeed (accidently i had enable litespeed enterprise) https://openlitespeed.org/kb/how-to-upgrade-openlitespeed/#CentOS_Downgrade
the sites wont show up
the mailserver works ok
i restarted the server but still sites wont work
i get the following message from chrome
This site can’t be reached
The webpage at https://electrodeals.gr/ might be temporarily down or it may have moved permanently to a new web address.
ERR_QUIC_PROTOCOL_ERROR
UPDATE********
after i updated packages from cyberpanel and restarted server i get a 404 error now
404
Not Found
The resource requested could not be found on this server!
Once you upgrade your server from openlitespeed to Litespeed Enterprise, you cannot shift back to openlitespeed. Let it be in Litespeed Enterprise for the sites to work.
Then create a new server, install cyberpanel and then remote transfer all the sites to this new server.
