I jus go a bit deeper and had a look into litespeeds config.
On the listeners (80 and 443) are only some of my alias domains. I fixed it manual.
Now I can access my domain with all my alias domain on port 80 http://
But it seems there is only one SSL Cert possible for the complete website! Everytime I issue a cet for one of my alias domains it will overwrite the cert for the website!
It´s clear: Websites cert is stored under
/etc/letsencrypt/live/main-domain.com
Did not found any place for alias-Domains certs.
Is this a bug?
It makes absolute no sense if every alias doain I can enter has the button “ISSUE SSL” if this button overwrites the only cert for the whole Website.
If I issue SSL for a domain it will be a Let´s encrypt cert. This works fine with the alias-domain I set it for, but it overwrites(?) all others alias-domains cert´s.
I start SSL for alias1. com → works
I issue SSL for alias2.com → works, but SSL for alias1.com is gone away and I get a cert warning
I have 6 alias-domains in sum. Just recognized it after I issued 6 SSL…
only can be happen with non-free “multipledomain certificate” …
if you want use a free one…
hmmmm
try cloudflare
domain A.tld create at CF then set IN A etc
then create another add site called DomainB.tld
set under proxy
at cyberpanel u only need to give same path of public_html
or some modification for advance user
because add domain with same path is not alias actualy… only domain forwarder if you use wordpress or similar cms. the BASE_URL will be back to the default one
except you already find out how to do that
Everytime I add a new alias Domain and issue a new Let´s encrypt cert, the cert cover the main Domain and the LAST Alias Domain. All other Alias Domains are deleted inside the Cert.
So by fact only ONE Alias Domain is currently possible to covered by build in let´s encrypt cert (as alias).
Is there are workaround? HHow can I issue a let´s encrypt cert for my maindomain coverng 5 alias domains?
Missing is a function / Button like “Issue SSL for ALL (selected) Alias Domains”
