Hello I’m not able to receive emails by CyberPanel, but I can send, I’m sure about MX records and I got 10/10 in mail-tester.
already this topic.
or try restarting postfix
command # systemctl restart postfix
or service postfix restart
thanks
I try to do all this steps but not working
Please share the logs to know the details of this error
what’s the credential for rainloop/admin ? I can’t sign in! , also I tried to test checktls.com I have the below results
You can find your rainloop admin password here : /usr/local/CyberCP/public/rainloop.php
make sure you have configured correct DNS settings for mails to work.
please private message me the DNS settings for your domain. I will take a look and guide you if its wrong.
Something seems wrong with your setup as mailserver or server connection is dropped and unable to reach.
Please upgrade your cyberpanel setup using this tutorial: 02 - Upgrading CyberPanel
After upgrading, restart the server and then check if all your issues are resolved or not. Do let us know how it goes through.
seems DNS are not set accordingly please connect your server with cyberpanel cloud I will enable debugger for you
still have same issue
I don’t understood
You can connect your cyberpanel to https://cloud.cyberpanel.net
You need to enable api on your cyberpanel to connect cyberpanel cloud.
same error my server
I am sending mail
but not received mail
