Hello
How can i fix LSAPI application, possible dead lock. ?
Try disabling modsecurity and restart litespeed.
In the past, I had some issues with modsecurity and i’m not sure if that has been patched as yet.
i disabled ModSecurity and restarted Litespeed also but as a not solved still i face the same issue help me ![]()
What version of cyberpanel are you running?
Is the error for one particular site or multiple?
also run killall lsphp
Big thank you to my dear friend the problem was fixed following your way
And your right also the new version was buggy need to fix more thing
Bugs or bugs cyber panel good for fewer traffic sites but not good for high traffic site this my experience
Check - Cyberpanel Highy Traffic
