Upgraded from version 1.8 build 4 to version 1.8 build 5. But there’s some issues,
Still that “Invalid SSL” persists
“admin” user “First” and “Last” name has vanished!
“Server IP Address” also vanished!
Although I don’t use “PowerDNS” but going to “panel/manageservices/managePowerDNS” shows “Error message: (1054, “Unknown column ‘masterServer’ in ‘field list’”)”
I will update this post if I find more issues ASAP!
If using Ubuntu do the same as above, then run Ubuntu update. (apt-get update && apt-get upgrade) if services are still not working.
Worked for two installations of mine. Ubuntu did not work until new updates got added
Is it really fixed? I know the update part, been using CyberPanel for 1+ years. Then again why CyberPanel team didn’t post an update about it if it’s really fixed? Let’s try upgrading and see what happens.
try run yum update, my centos worked straight away once updated again on 1.8.5
Ubuntu I downgraded to 1.8.4 then upgrade to 1.8.5 then 1.8.5 again after service status got fixed
See this thread for note about fixed, 3 up from bottom
check powerdns version, it should be 4.2 on 1.8.5 It may not have been updated even though you do not use
@bsanz16 bro! All of my services are okay! I can restart or pause any service through panel! My only issues are these,
@bsanz16 if I am not wrong, issue 1-3 is more likely a “typo”. For issue 4 that is another case. @CyberPanel needs to dig more to gain what that issue is. Who knows maybe that’s also a “typo” sort of issue or any integration related issue.
