Hi I accidently changed my cyberpanel default port from 8090 to 80 what should I do and how can I revert the step.
good question
hope someone have the answer
you can revert it the same way as you changed it ?
Greetings from PowerChaos
Thanks a lot
/usr/local/lscp/conf/bind.conf
in this file you can change port and before changing port make sure you add that in fire wall and you cant run the cyberpanel on 80, 443 and other like that which are already used by any other process.
I hope cyberpanel will block process if someone put 80 on default Cyberpanel port… and give a warning.
