CyberPanel Community
ClosedHow to uninstall spamassasin on Centos 7
ky
kyu #1
Hi, I’m using windows and cyberpanel I only saw instructions for ubuntu and other OS. Is there some way for me to remove spamassasin? Thank you
ky
kyu #2
There must be some solution? Please, it’s absolutely destroying the server CPU
ky
kyu #4
Hey, its CentOS 7 64bit with CyberPanel
ky
kyu #6
Server and website about 2 months old now. Installed spamassasin yesterday
jo
josephgodwinke #7
Try
$ yum remove spamassassin
Using this server os is discouraged for new installations. Your installation was setup after the caveat came out 01 - Installing CyberPanel
PLUS
ky
kyu #8
hey thanks, but that the thing I don’t understand do i do that on my windows prompt? or where do i run that command?
ky
kyu #10
Ah ok, thanks a lot, will do that now
jo
josephgodwinke #11
For centos you have to nuke these directories and their files
rm -rf rm -rf /etc/mail && rm -rf /etc/mail/spamassassin && rm -rf /etc/sysconfig/spamassassin
rm -f /usr/bin/spamassassin
rm -f /usr/bin/spamc
rm -f /usr/bin/spamd
rm -f /usr/lib/systemd/system/spamassassin.service
rm -rf /usr/share/doc/spamassassin-*
rm -f /usr/share/man/man1/sa-awl.1.gz
rm -f /usr/share/man/man1/sa-compile.1.gz
rm -f /usr/share/man/man1/sa-learn.1.gz
rm -f /usr/share/man/man1/sa-update.1.gz
rm -f /usr/share/man/man1/spamassassin-run.1.gz
rm -f /usr/share/man/man1/spamassassin.1.gz
rm -f /usr/share/man/man1/spamc.1.gz
rm -f /usr/share/man/man1/spamd.1.gz
rm -rf /usr/share/spamassassin
rm -rf /var/lib/spamassassin
rm -rf /var/run/spamassassin
Please think of changing os to ubuntu 20.04 or AlamaLinux 8.3 in future
jo
josephgodwinke #13
It shows yyou were prompted to run update and you agreed to run the update. You have to wait for system update to finish to uninstall spamassassin
ky
kyu #14
It’s not doing anything in the terminal console? Even the update just stays at 5% I left it open for 20mins not showing anything but 5%
‘$ yum remove spamassassin’ and enter also does nothing just opens new paragraph?
If i delete spamassasin folder in SFTP window? Would that do the trick?
jo
josephgodwinke #15
That has nothing to do with spamassassin or cyberpanel. That is related to hostinger vps. Contact support for help.
ky
kyu #18
No I was wrong last reply, I just had to wait a bit longer, not used to command prompts, it erased it now. It just needed yum remove spamassassin without the $ sign
To erase these do I run a command or manually erase from folders?
