I’ve Recently Changed my VPS Provider and Need to Migrate my current CyberPanel Sites, Accounts etc to My New VPS ?
Any idea or Tutorial How can i do it?
Thanks in Advance.
Thanks in Advance.
Cool,
Thanks for this awesome feature.
really love it @CyberPanel
@CyberPanel @usmannasir Any bug or issue while using this ? Any open issue in this tool like SSL copy or any?
Fyi…this doesn’t work if you use a custom SSH port. It must be 22 for it to complete the transfer. Not sure if it’s a bug, or by design.
One more bug. None of the WordPress database passwords came over successfully with the Remote Backup. I got “Error establishing a database connection” on all of them. Copying the password from wp-config.php and “changing” it in the Cyberpanel Database area fixed it right up.
Do you mean the remote(source) SSH port needs to be 22 or the local(destination) SSH port needs to be 22?
Hi @BlueSquares some characters are prohibited in mysql user’s passwords, these are: ; && | …
@timnolte remote (source) ssh port needs to be 22 - this is by design and stated on page: backupDestinations.html
“Set up Back up Destinations (SSH port should be 22 on backup server)”
Cheers!
