How to access Rainloop Admin Panel (2)
@die2mrw007 Thank you so much for the help. I found the password and I can now login Rainloop Admin.
However, the new problem I discovered is that incoming mails are no longer showing in INBOX or any other folder. I can send mails and the recipient will recieve. But when they send me email, I will not recieve. This happend after I followed @usmannasir instruction here: Filtering Spam in RainLoop, AutoReply and Email Filters with Sieve
I marked the previous thread as “Solution” and I can no longer post reply.
Are you receiving mails in spam folder?
If yes, then make sure you configure DKIM, spf, dmarc txt records in DNS for secure valid mails to not have them marked as SPAM
