CyberPanel Community
ClosedHow do I get Cyberpanel to recognise a newly added volume not "/"?
EC
Edward Cox #1
Hi, brand new users here. Am using Hertzner USA to run my cloud CyberPanel. Started with 40GB storage on ‘/’. Just added another 40GB volume that is attached probably different /mnt point. However CyberPanel only seems to recognise ‘/’ - Is there some config in CyberPanel I need to do to make it recognise the additional volume?
Thank you for your time and effort.
Kind Regards,
Edward
RM
Rana Muhammad Usman Nasir #2
If you are meaning to store backups at /mnt then you can do so without CyberPanel knowing it.
CyberPanel only recognize / but that does not mean you can not use it for backups or anything else.
EC
Edward Cox #3
Hi thank you for replying. No to backups. Just want to have 80GB available for websites instead of 40GB. Does that make sense? Thank you, Edward
RM
Rana Muhammad Usman Nasir #4
For that rather then adding volume, upgrade your hetzner plan and you will get more disk and they will give you docs to extend your / file system.
I don’t remember if hetzner cloud uses lvm in that case you can use volume too. But this will be complex.
PS: CyberPanel can’t use /mnt space for creating sites.
EC
Edward Cox #5
Sounds like sound advice. Thank you again.
WS
Wahyu Septiawan #6
I have the same problem, have you found a way? if so can you tell me?
EC
Edward Cox #7
As the awesome [usmannasir] mentioned in the solution " For that rather then adding volume, upgrade your hetzner plan and you will get more disk and they will give you docs to extend your / file system."
So adding a new Volume will not be recognised, however if your Provider offers Rescaling then you might have better luck. :slight_smile:
WS
Wahyu Septiawan #8
I don’t rent like that, I have my own server. An ordinary PC that was modified into a server with a 500GB disk capacity…
then what should i do to expand /filesystem. if I don’t rent
