When I restore a domain account in a new installation of cyberpanel from a backup:
backup-domain.com-10.03.2024_07-00-40.tar.gz
The restoration works, all files and databases are installed.
The same user for the account is there from the CyberPanel where the backup was taken.
The result is wordpress saying: Critical Error
When I go to CyberPanel File Manager to “Fix Permissions” is says ok BUT I can not change, edit or delete any files in the file manager.
So it seems the files are there but I can not control them.
Any ideas what the problem is?
This only happens on one very old domain.
The only “Fix” I have that works is to create a new website in CyberPanel for that domain, Install wordpress and restore the site using UpDraft (Plugin) and then it works normally.
Is this the right place to ask for this help?
