after removing the records then i will be able to add new related records
Are you there sir?
Keep default_domainkey only. Delete everything else in that red box.
Yes. You can add the records as advised in previous post
ok thanks…let me perform these actions
wait plz
but I could not find “default_domainkey” values from the following list
Can you highlighte the default_domainkey" in following list so that i can add plz?
Seems you dont have DKIM keys.
Can you confirm you have DKIM keys here https://SERVER_URL:8090/email/dkimManager
Read through this Tto generate DKIM Keys How to Manually Set up SPF, DKIM and DMARC Inside CyberPanel
let me see this plz
All those cpanel records should be deleted. Leave autoconfig and autodiscover records for exchange accounts to work properly plus dont proxy those records.
Good now you need to copy the public key and create a default._domainkey in your cyberpanel dns manager.
Confirm this record is same as in cloudflare. Read this keenly to understand HOW and why to add this record [TUTORIAL] How to setup DNS configurations for CyberPanel
i could not fin field to write" default._domainkey"
Also added same default._domain key record in “cloudflare”
see plz
now what is need to do?
Is every record ok now?
