When I try to select directly a subdomain like “laboutiquefrancaise.psweb.fr”
I’ve got this error:
Cannot fetch records. Error message:Domains matching query does not exist.
what is your domain name ?
you want connect using ip or domain ?
if ip that will dificult to make https and not cheap
if domain you should check dns etc etc
manage your subdomain from primary domain…
i have already reported this but it look developer want to keep that way…
if you already can login to your panel…
create file.html at public_html (main domain)
insert text “anything”
call the url https://domain/anything.html
and create same file (not copy)
at subdomain (cyberpanel language:domain)
http://laboutiquefrancaise.psweb.fr/ failed… ok then
clear your htaccess…
set the ip as DNS ONLY at cloudflare (gray not orange) (i think you already do this)
or disable services from cloudflare
then purge all cache from cloudlfare
