im still unable to send did i miss something?
Oct 24 19:02:07 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4882, TLS, session=<8sFkH/54sAB/AAAB>
Oct 24 19:02:07 trg postfix/submission/smtpd[4786]: connect from localhost[127.0.0.1]
Oct 24 19:02:07 trg postfix/cleanup[4788]: 45D8D4894EC: message-id=[email protected]
Oct 24 19:02:07 trg postfix/qmgr[4711]: 45D8D4894EC: from=[email protected], size=875, nrcpt=1 (queue active)
Oct 24 19:02:07 trg postfix/submission/smtpd[4786]: disconnect from localhost[127.0.0.1]
Oct 24 19:02:07 trg dovecot: imap([email protected]): Disconnected: Logged out in=11 out=401
Oct 24 19:02:07 trg postfix/pipe[4793]: 45D8D4894EC: to=[email protected], orig_to=, relay=dovecot, delay=0.02, delays=0.01/0.01/0/0.01, dsn=2.0.0, status=sent (delivered via dovecot service)
Oct 24 19:02:07 trg postfix/qmgr[4711]: 45D8D4894EC: removed
Oct 24 19:02:07 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4889, TLS, session=<gEpoH/54tgB/AAAB>
Oct 24 19:02:07 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=867
Oct 24 19:02:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4892, TLS, session=<kdkiIP54uAB/AAAB>
Oct 24 19:02:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=89 out=860
Oct 24 19:02:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4893, TLS, session=<HEcjIP54ugB/AAAB>
Oct 24 19:02:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=1094 out=1232
Oct 24 19:02:20 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4895, TLS, session=<s3soIP54vAB/AAAB>
Oct 24 19:02:20 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=867
Oct 24 19:02:48 trg postfix/smtpd[4875]: connect from 211-72-92-231.HINET-IP.hinet.net[211.72.92.231]
Oct 24 19:02:49 trg postfix/smtpd[4875]: warning: 211-72-92-231.HINET-IP.hinet.net[211.72.92.231]: SASL LOGIN authentication failed: Invalid authentication mechanism
Oct 24 19:02:49 trg postfix/smtpd[4875]: disconnect from 211-72-92-231.HINET-IP.hinet.net[211.72.92.231]
Oct 24 19:03:20 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4900, TLS, session=<E3C7I/54wAB/AAAB>
Oct 24 19:03:20 trg dovecot: imap([email protected]): Disconnected: Logged out in=1094 out=1220
Oct 24 19:03:20 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4902, TLS, session=<moDAI/54wgB/AAAB>
Oct 24 19:03:20 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=867
Oct 24 19:03:56 trg postfix/anvil[4728]: statistics: max connection rate 1/60s for (smtp:190.85.234.7) at Oct 24 18:53:56
Oct 24 19:03:56 trg postfix/anvil[4728]: statistics: max connection count 1 for (smtp:190.85.234.7) at Oct 24 18:53:56
Oct 24 19:03:56 trg postfix/anvil[4728]: statistics: max cache size 1 at Oct 24 18:53:56
Oct 24 19:04:15 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4905, TLS, session=<o2MFJ/54xAB/AAAB>
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: warning: cannot get RSA certificate from file /etc/pki/dovecot/certs/dovecot.pem: disabling TLS support
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: warning: TLS library problem: 4906:error:0200100D:system library:fopen:Permission denied:bss_file.c:402:fopen(‘/etc/pki/dovecot/certs/dovecot.pem’,‘r’):
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: warning: TLS library problem: 4906:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:404:
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: warning: TLS library problem: 4906:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:701:
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: connect from localhost[127.0.0.1]
Oct 24 19:04:15 trg postfix/cleanup[4909]: 463644894EC: message-id=[email protected]
Oct 24 19:04:15 trg postfix/qmgr[4711]: 463644894EC: from=[email protected], size=875, nrcpt=1 (queue active)
Oct 24 19:04:15 trg postfix/submission/smtpd[4906]: disconnect from localhost[127.0.0.1]
Oct 24 19:04:15 trg dovecot: imap([email protected]): Disconnected: Logged out in=11 out=401
Oct 24 19:04:15 trg postfix/pipe[4914]: 463644894EC: to=[email protected], orig_to=, relay=dovecot, delay=0.05, delays=0.03/0.02/0/0.01, dsn=2.0.0, status=sent (delivered via dovecot service)
Oct 24 19:04:15 trg postfix/qmgr[4711]: 463644894EC: removed
Oct 24 19:04:15 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4917, TLS, session=<yIQJJ/54ygB/AAAB>
Oct 24 19:04:15 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=867
Oct 24 19:04:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4920, TLS, session=<z29FJ/54zAB/AAAB>
Oct 24 19:04:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=89 out=860
Oct 24 19:04:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4921, TLS, session=<V8VFJ/54zgB/AAAB>
Oct 24 19:04:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=1094 out=1220
Oct 24 19:04:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4923, TLS, session=<gbZJJ/540AB/AAAB>
Oct 24 19:04:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=868
Oct 24 19:04:19 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4925, TLS, session=<k/NKJ/540gB/AAAB>
Oct 24 19:04:19 trg dovecot: imap([email protected]): Disconnected: Logged out in=1094 out=1221
Oct 24 19:04:20 trg dovecot: imap-login: Login: user=[email protected], method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4927, TLS, session=<NB1PJ/541AB/AAAB>
Oct 24 19:04:20 trg dovecot: imap([email protected]): Disconnected: Logged out in=96 out=868
