hi i recently installed cyberpanel in my vps i was wondering if i can deploy node.js
Deploy node.js in cyberpanel
Yes you can. Few members here have already mentioned the process to get it successfully installed. Try searching for the same here and you may find it.
Hi Nevin,
Did you find it how to deploy node js project?
nope, could you send a link to the post?
Setup Express.js Application on CyberPanel/OpenLiteSpeed check this maybe help full there are many threads please search
I got the answer from here: Proxy Preserve Host
Your application should be running in port, something like this 127.0.0.1:3000.
What you can do is to go to Websites > List of websites > Pick your website > Manage option. There you will find the vHost Conf section, there you should paste this:
extprocessor appname {
type proxy
address 127.0.0.1:your_app_port (3000 for this example)
maxConns 100
pcKeepAliveTimeout 60
initTimeout 60
retryTimeout 0
respBuffer 0
And the last step would be pasting the following in the Rewrite rules section
RewriteEngine On
RewriteRule ^(.*)$ HTTP://appname/$1 [P]
Best of luck!
Now it’s all easy
