CyberPanel - WebHosting Control Panel Based Purely On OpenLiteSpeed
does anyone know how big the fresh installation cuber panel and the wordpress. I installed the cyber panel multiple time and setup wordpress al up and running. and the disk usage is about 6G. does really take like this much ?
While I used to use Cyberpanel a year ago I discontinued due to having to use 2 panels (CP and OLS) to do basic things like add ip’s and edit configs.
Is there any roadmap for integrating OLS items into Cyberpanel so don’t have to switch between 2 admin panels?
Greetings, I am new here. How do I post a new topic?
My issue is:
How do I create a Cpanel equivalent in Cyberpanel? Thanks for your attention.
The new version of cyberpanel (2.1.1) looks (and is) a fake of underdeveloped schoolchildren. Full of bugs and errors. the feeling that the developers were very hacky and did not even test their creation
I can’t send emails, just receive, there is no apparent error, the email even goes to the “sent” ones, but it doesn’t reach the destination!
Alguien que me ayude mi pagina web en lugar de cargar descarga un archivo. Ayudenme por favor!
Ssl problems on all servers, what is going on?!
No www → without www, http to https redirects in the settings of web domain, no the button for disable LE for a domain, bugs in the languages system, except to English
a little confused
I figured out the redirects and language files.
there is currently an issue caused by acme as mentioned in this discussion: https://forums.cyberpanel.net/discussion/5526/
please follow this guide to resolve the issue: https://pcx3.com/cyberpanel/cyberpanel-self-signed-certificate-issue/
Type your commentCan anyone help me, site just doesn’t run.
4GB 2 core VPS with 7 cent.
I installed cloud.cyberpanel and wordpress, the site with a native theme just doesn’t run.
Hi @veicular
Is any error message displayed at all? anything in the error log?
As standard WP troubleshooting: enable debug and PHP error reporting, and go through the messages - depending on them check PHP version, db connection, etc.
Digite seu comentário> @stefanepejcic said:
Hi @veicular
No log reporting
define(‘WP_DEBUG’,true);
define(‘WP_DEBUG_DISPLAY’,true);
openlitespeed simply locked
Now test on ServerS Hosting Now Vultr The result is the same every time.
The installation is clean and does not run.
all hosting (VPS) with cents 7 4GB and 2 Core
I created a website but the file is not creating the file manager as well as folder
Thank you for help not required. I found the cause and fixed the problem.
[10.11.2021_16-44-44] [ERROR] We are not able to run apt-get -y install openlitespeed return code: 100. Fatal error, see /var/log/installLogs.txt for full details.
