CyberPanel by default does not use CSF, so I recommend to not enable CSF until your issue is resolved.
The second thing is you have a normal starter license, CyberPanel requires starter license with CyberPanel bundle, that you can get from CyberPanel Enterprise - CyberPanel
do not use CSF the same results … Can not open all ports that I reported.
I use this tutorial :
To install CyberPanel Ent, you first need to obtain a license key (it is free for 1 domain, but you still need to obtain the key). Visit the pricing table to decide your desired plan.
Obtain a License!
Before running the installation, you need to obtain a license. A license key will be asked for during installation.
Installation
On you’re on the command line terminal run the installation script as a single command:
[06-24-04-Mon-Apr-2019] [ERROR] We are not able to CyberPanel Make Migrations return code: 1. Fatal error, see /var/log/installLogs.txt for full details [download_install_CyberPanel]
[03-19-19-Mon-Apr-2019] CyberPanel Download successful
[03-19-19-Mon-Apr-2019] Extract CyberPanel [download_install_CyberPanel]
[03-19-21-Mon-Apr-2019] Extract CyberPanel successful
[03-19-21-Mon-Apr-2019] Updating settings.py!
[03-19-21-Mon-Apr-2019] settings.py updated!
[03-19-21-Mon-Apr-2019] CyberPanel Make Migrations [download_install_CyberPanel]
[03-19-22-Mon-Apr-2019] [ERROR] We are not able to CyberPanel Make Migrations r$
Any chance anyone can provide us with a working demo? I would love to see it in action.
If I could use CyberPanel instead of cPanel, and Open Litespeed instead of Enterprise, that would be a $50/mo savings. So a demo would be most welcome. (the “unofficial” demo doesn’t work.)
Since it is free you can spin up a KVM virtual machine at any provider and get hands-on experience, installation is just one command and costs nothing, more details here → 01 - Installing CyberPanel - Docs - CyberPanel Community
Oh My God! I am falling in love with this panel. Surely going to install on my next server. After CPanel raised their price I finally found a real alternate! Fast, Secure and Simple.
No meu caso, o CyberPanel só permite instalar script pré instalados como: Wordpress, magentto, prestashop que ja vem com cyberpanel.
ao instalar pela forma manual seguindo os passos: Criar banco de dados, subir arquivos para ficheiro e instalação apresenta erros: Failed to load resource: the server responded with a status of 500 (Internal Server Error)
