Hello to all !
I’m new on this forum community and I’m sorry if my topic is not on right category.
I have changed my default port from 8090 to 80 and now I can’t access to Cyberpanel.
I made the change from panel settings and after saving it I can’t access to panel page.
How can I fix this from console ?
I have root access but I don’t know which file or files should modify to make cyberpanel work again.
Please help me to resolve this issue.
Thank you in advance!
Thanks a lot but I tried and this is not fixing my problem.
I put to bind.conf *.8090 and use grep command but it’s not working.
I can’t access to my cyberpanel page…
Other possible solutions ?
I really need your help to access my cyberpanel.
Which files I must modify to change port ?
i think that the link i gave to you is already have step by step info to restore port to 8090
and some comment there is mention about change port
I have fixed with restore from backup.
Thanks for helping to everyone in this thread !
I really tried to use tutorial (post in this forum) but it doesn’t fixed my problem.
Again, thanks to all !
then
how you fix it ?
let us know … to help other if they found similar problem
The reason you’re locked out is that you forgot to whitelist the new port in the firewall (If it is enabled).
I found this tutorial on how to use SSH to revert back to 8090.
To file:
/usr/local/lscp/conf/bind.conf
add:
*:YOUR_PORT
and in any file in
/usr/local/CyberCP/
change hard-coded port 8090 to YOUR_PORT:
grep 8090 /usr/local/CyberCP -rl |grep -v “.php\|.css\|.js\|.pem\|.html\|.png\|site-packages”|xargs -i sed -i ‘s/8090/YOUR_PORT/’
