na
nafio
#1
will cyberpanel work for ubuntu 22.04 lts?
Not yet, litespeed don’t support 22.04.
it does now
is it works now? should i upgrade ubuntu to 22.04? will it still works?
It is not recommended you do not upgrade your server os. Install a clean os and try CyberPanel.
if its not supported then i stay on 20.04
i got cp running on server 20.04 and update pops up, dont want break it
