Yes rlcone config file, while doing backup of emails, the user does not have access to rclone backend file.
When the command runs as root it obviously canβt find the rclone backend as rlcone looks into the user directory, thus if we can pass the path of config file manually, it will solve the issue.
Just saw that rclone seems to support the XDG_CONFIG_HOME and RCLONE_CONFIG env variables.
So, you can either set XDG_CONFIG_HOME which would use $XDG_CONFIG_HOME/rclone/rclone.conf or directly specify the config file in the env variable RCLONE_CONFIG.
Still, Iβll open an issue to let rustic set rclone options.
Did you manage to add it by any chance?
@usmannasir You just have to set the RCLONE_CONFIG environment variable. I think this already works with all rustic versions.
If multiple backups run at same time, this can cause conflict.
Can you describe what kind of conflicts you mean?
Sorry got caught up in something, I manage to set the env variable, thanks alot.
aawsome:
RCLONE_CONFIG
nlkocx
April 2, 2023, 5:26pm
110
Is it possible to use hetzner storage boxes for backups?
We had voting in our Facebook groups, hetzner storage box didnt got much votes, but in later releases we can include it.
doug
April 4, 2023, 10:59am
112
We can use hetzner storage boxes as a SFTP destination, but it gives us errors.
nlkocx
April 6, 2023, 8:08pm
113
What will work now? s3? what if I mount Storage Box via Samba/CIFS?
I will create a video tutorial around it, basically as of this current release you can configure two sort of rclone backends from gui. However virtually you can configure any rclone backend manually from cli and CyberPanel will detect it and it will work just like a backup configured from UI.
I was doing my final tests and ran into this
root@v2tests:~# sudo -u vtest8202 rustic -r rclone:v2test:v2testbackup.oso5ecswoq.cyberpanel.website snapshots
using no config file (./rustic.toml doesn't exist)
enter repository password:
[INFO] repository rclone:v2test:v2testbackup.oso5ecswoq.cyberpanel.website: password is correct.
[INFO] using cache at /home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba
snapshots for (host [v2tests], label [], paths [/home/backup/v2testbackup.oso5ecswoq.cyberpanel.website/config.json,/home/v2testbackup.oso5ecswoq.cyberpanel.website,vB8ajaWbNO67rx.sql])
| ID | Time | Host | Label | Tags | Paths | Files | Dirs | Size |
| 4054489e | 2023-04-11 21:48:15 | v2tests | | | /home/backup/v2testbackup.oso | 3275 | 400 | 88.7 MiB |
| | | | | | 5ecswoq.cyberpanel.website/co | | | |
| | | | | | nfig.json | | | |
| | | | | | /home/v2testbackup.oso5ecswoq | | | |
| | | | | | .cyberpanel.website | | | |
| | | | | | vB8ajaWbNO67rx.sql | | | |
| 25d98af0 | 2023-04-11 22:01:42 | v2tests | | | /home/backup/v2testbackup.oso | 3285 | 412 | 89.1 MiB |
| | | | | | nfig.json | | | |
2 snapshot(s)
Then while i try to dump the database
root@v2tests:~# sudo -u vtest8202 rustic -r rclone:v2test:v2testbackup.oso5ecswoq.cyberpanel.website dump 4054489e:vB8ajaWbNO67rx.sql --password ""
[00:00:00] ββββββββββββββββββββββββββββββββββββββββ 0/0 [INFO] getting snapshot...
[00:00:00] reading index... ββββββββββββββββββββββββββββββββββββββββ 8/8 Error:
"vB8ajaWbNO67rx.sql" not found
it says vB8ajaWbNO67rx.sql not found, although its present in the snapshot.
Can you run rustic ls 4054489 to check the contents of this snapshot?
If in the output vB8ajaWbNO67rx.sql is missing: Can you tell me which command(s) you used to create that snapshot?
@aawsome
command used for backup
mysqldump --defaults-extra-file=/home/cyberpanel/.my.cnf -u root --host=localhost --port 3306 --add-drop-table --allow-keywords --complete-insert --quote-names --skip-comments vB8ajaWbNO67rx | sudo -u vtest8202 rustic -r rclone:v2test:v2testbackup.oso5ecswoq.cyberpanel.website backup --stdin-filename vB8ajaWbNO67rx.sql - --password "" --json 2>/dev/null
See the output below, looks like something really strange is going on in terms of path inside rustic, please note that this is a merged snapshot, so it contains other files as well. I see a stdin file at the end.
"home"
"home/backup"
"home/backup/v2testbackup.oso5ecswoq.cyberpanel.website"
"home/backup/v2testbackup.oso5ecswoq.cyberpanel.website/config.json"
"home/v2testbackup.oso5ecswoq.cyberpanel.website"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/data"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/data/30"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/data/30/30e71493aa4fec41ef15e035c796cd997bf06114723fac8d2eef82626af9f6d0"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/data/c8"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/data/c8/c8d25fcb7ad99115f9a19db3f6b978757ebdc810ca9d4574f387ded15c4b5882"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/.cache/rustic/334bf000470161e8980cbeba79a40b2db566dd954ce0814df8b4740b9f871cba/index"
"home/v2testbackup.oso5ecswoq.cyberpanel.website/public_html/xmlrpc.php"
"stdin"
Update: on another non-ubuntu system, everything work as expected
"home/cyberpanel.net/public_html/wp-includes/wp-diff.php"
"home/cyberpanel.net/public_html/wp-links-opml.php"
"home/cyberpanel.net/public_html/wp-load.php"
"home/cyberpanel.net/public_html/wp-login.php"
"home/cyberpanel.net/public_html/wp-mail.php"
"home/cyberpanel.net/public_html/wp-settings.php"
"home/cyberpanel.net/public_html/wp-trackback.php"
"home/cyberpanel.net/public_html/xmlrpc.php"
"home/cyberpanel.net/usman.jVceqzQ175.cyberpanel.website"
"home/cyberpanel.net/usman.jVceqzQ175.cyberpanel.website/index.html"
"qf4fza8IocVVqU.sql"
"yKtbkp1THRlmBk.sql"
Update 2: Rather then picking the name from stdin, it is just calling it stdin
root@v2tests:~# sudo -u vtest8202 rustic -r rclone:v2test:v2testbackup.oso5ecswoq.cyberpanel.website ls 03725241
[00:00:00] reading index... ββββββββββββββββββββββββββββββββββββββββ 12/12
"stdin"
aawsome
April 12, 2023, 10:56am
118
Looks like does not happen on alma linux but on ubuntu only? Because on almalinux I see correct files.
pryce
April 12, 2023, 3:36pm
120
Working together for open source. Very good! Looking forward to this major update.
The fix is included the the just-released version 0.5.1
