Salutations,
There is no way I can connect with fileZille to my directory of any of my sites on CyberPanel.
I created the account on Cyberpanel FTP / CREATE / …
I activated ports 21, 40110 - 40210 but if I try to connect it gives me the following message …
log ? error log?
try to re create and try to copy paste the cred to notepad before to ftp client (try other simple popular ftp client)
watchout for blank space…
check firewall…ftp port
there is billion way to fix it
if you only give to us only a little info and what you did before error and what you do after you find error and before post here/…
I created the ftp account on Cyber Panel, I activated port 21 on the server (ubuntu 20.4) but it did not work, I pasted the credentials in the notepad but it did not work, I deactivated the firewall but it did not work, I created 3 ftp accounts and none it worked …
I don’t know what else to try
update:
i will ignore the domain name. since the domain name pointing to other places and you request ftp using IP. so that is not the problem…
have you try to using non secure ?
since 34.147.53.175 not have valid SSL yet
I inform you that when I opened cyberpanel I had set another hostname and it worked correctly but then I had to delete the domain so now I have set server.spuntolab.it but it does not work, may it have to do with the ssl problem? what can I do??
I controll and copy the right username and pass of ftp account that i was create.
i will tell you something that maybe not related with your problem
i was facing problem with ftp using hostname (server hostname) and client domain name.
but that was happen on 2.1.1
and that still happen include mail ssl if i put it under Cloudflare proxy…
so , starting that day. i always put my domain (server hostname) not behind cloudflare proxy (gray mode) and until now i can login using FTP https://1drv.ms/v/s!AnxcThy_1nJ671dlaZ1-_prKidTV?e=lNp75Y
and i always using default ftp or native ftp
some of ftp client will make trouble like filezilla
so i use 2 ftp client… winscp and total commander (so far this two ftp client have zero trouble, except ssl mode)
