I just installed cyber panel on my server runing ubuntu 20 and i created a datebase using the create datebase of the cyberpanel, but when i try to connect to the mysql datebase on my local computer i get the error :
mysql.connector.errors.DatabaseError: 2003 (HY000): Can’t connect to MySQL server on ‘IP Address’ (10060)
If I connect on localhost it works fine but if I want to connect to the database remotely the error pops up
during installation i saw :
Remote MySQL (default N):
Allow for your Database to be installed on a remote server*
i left everything to the default which is No, does this mean i cannot connect to mysql remotely?
Okay thank you so much @josephgodwinke , I’m checking now, i will let you know if it works
according to the toturial:
I have added the port 3306 with the ability to allow any connection from any IP by seting the IP Address to 0.0.0.0/0
but i keep getting
Access denied for user ‘local4888’@‘localhost’ (using password: NO)
when i want to connect mysql on my local host
so ignore creating a new user from CLI and i created in phpmyadmin but i still cannot connect to mysql remotely.
Is it compulsory to create mysql user in CLI before i can connect to the database remotely
no i run the Local environment section.
what they they refer to as local and production environment?
Did you run
GRANT ALL PRIVILEGES ON *.* to 'yourdbusernamehere'@'youripv4publicaddressforCyberPanelserver' IDENTIFIED BY 'yourdbpasswordhere';
on your ssh terminal connected to the cyberpanel server
do i didnt beacuse i connect login mysql on ssh
The error is on cyberpanel server?
the error occur when i try to run this step
i log in ssh as a root user and it works
But i still connect connect to msql remotely. do i have to restart my server?
Set a password for this user on mysql console
ALTER USER 'local4888’@‘localhost’IDENTIFIED BY 'littlewhale';
this user is was not even amount my DB users, it is cypanel user created automatically on website creation
You need to add a new user with all privileges and use that user but you can alter that user with root privileges but first address the no password issue Cannot connect to database on a remote machine - #16 by josephgodwinke
You also go to https://SERVER_URL:8090/dataBases/listDBs and change the password for that user first then grant root privileges
I finally got it fix using this tutorial How to Allow Remote MySQL Connections
So the iptables part helped you on top of firewalld part or you did not touch the firewalld?
system
Closed
December 10, 2022, 3:20pm
22
