Blank page on phpmyadmin
I did a fresh install of ubuntu 22 on a OVHCloud dedicated server.
I installed litespeed enterprise + cyberpanel from this command line :
sudo su - -c "sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)"
I did absolutely nothing else, and I get a blank page when I want to open phpmyadmin from cyberpanel.
I can see with the chrome dev tools a file still waiting to load : domain.com:8090/phpmyadmin/phpmyadminsignin.php
I tried the solutions found on the forum, but none worked. Do you have any ideas?
Current Version: 2.3
Build: 4
Current Commit: 93bf01922d2f4a9cb52a375809f94e0ed293cc2a
Latest Version: 2.3
Latest Build: 4
Latest Commit: 93bf01922d2f4a9cb52a375809f94e0ed293cc2a
Welcome @Valentinh Happy you are here
Using ssh terminal confirm you have phpmyadmin and get phpmyadmin if you dont have it like this
# as root or sudouser
# does this folder exist ?
$ find /usr/local/CyberCP/public -name phpmyadmin
# no it does not
$ wget -cv https://raw.githubusercontent.com/josephgodwinkimani/cyberpanel-mods/main/phpmyadmin.zip -P /usr/local/CyberCP/public
$ cd /usr/local/CyberCP/public && unzip phpmyadmin
Go back and try to access phpmyadmin
Hi @josephgodwinke,
Thank you for your response.
The folder actually exist
**ubuntu@VWC-UBUNTU**:**~**$ sudo find /usr/local/CyberCP/public -name phpmyadmin
/usr/local/CyberCP/public/phpmyadmin
/usr/local/CyberCP/public/phpmyadmin/vendor/phpmyadmin
$ mv /usr/local/CyberCP/public/phpmyadmin /usr/local/CyberCP/public/phpmyadmin_old
Run this part
I ran this section of code and then rebooted the server. But the problem is still here
Confirm you have the same mysql passwords here for root /usr/local/CyberCP/CyberCP/settings.py, /etc/cyberpanel/mysqlPassword and from mysql console
I checked and yes, passwords are the same
Its a 404 error or 500 error you see in console for this file ?
It’s for a long time in “pending”. And after a few minutes, i have a 500 error on the page.
Log into your cyberpanel dashboard and go to this link http://domain.com:8090/phpmyadmin/index.php?server=1
I have a 500 error on this page
This seems like phpmyadmin via the phpmyadminsignin file cannot seem to get the token to execute an autologin or even a direct log in where it asks for a password and username.
I would ask you change root password Some Dont's After Installing CyberPanel!
I changed the password for theses files :
/usr/local/CyberCP/CyberCP/settings.py (rootdb password part)
and
sudo systemctl restart lscpd
But I still can’t access to phpmyadmin page :no_mouth:
I did a test on a fresh install of Ubuntu 20, and it works.
What is wrong with Ubuntu 22 :sweat_smile:
change
session.auto_start=1
to
session.auto_start=0
fixed for me
Where did you change this?
I have same issue loads for e few minutes and then returns 500 error. Same for phpmyadmin, same for ImunityAV. Any suggestions?
Solved for me
also solved for me
