Hi Guys,
Any thoughts on why backups are not working when going through a CDN?
Not sure what you are trying to say?
My Google Drive Backups are not working for the websites that are going trough the quic.cloud CDN.
If I try to backup them manually in the Home folder, they are not working as well.
If I disable the quic.cloud CDN and try to backup everything is working correctly. Does the backups have something to do with the server IP adress?
that has nothing to do with quic cloud. Could be something else, check cyberpanel main log file . backups for other domains working?
You are right, it has nothing to do with quic.cloud. I tought it has because one of the sites was continueing to work properly, weird.
It has something to do with this error I guess:
[03.20.2022_10-59-44] (1045, "Access denied for user 'root'@'localhost' (using password: YES)") [207][5009]
[03.20.2022_10-59-44] YniiMIc6IG1mVAAeoR3h6FuKKxcWH1pf-u tanch5324 echo '/home/t==example.com/backup/status [207][5009]' > /home/example.comt/backup/status
[03.20.2022_10-59-44] YniiMIc6IG1mVAAeoR3h6FuKKxcWH1pf-u tanch5324 echo '(1045, "Access denied for user 'root'@'localhost' (using password: YES)") [1084][5009]' > /home/www.example.com/backup/status
[03.20.2022_10-59-46] YniiMIc6IG1mVAAeoR3h6FuKKxcWH1pf-u tanch5324 cat /home/www.example.com/backup/backupFileName
Im going to research.
Thanks.
You shall find your answers here → Some Dont's After Installing CyberPanel!
You are great guy man. Thank you. Freaking mysql password. I tought that by changing it in /etc/cyberpanel/mysqlPassword everything is ok but obviusly not :D.
Problem fixed.
