Dear Cyberpanel Team ,
I have an Angular project with SSR and uploaded the dist folder which it has browser and server folder into public_html but SSR is not working could you please help me to run the Angular SSR server on Cyberpanel ,
Thanks,
Hello @ahmed1001
Did you setup nodejs and pm2 to consume this app ?
Hello Sir ,
Yes Already Installed
Hello Sir ,
Yes Already Installed how can i run main.js from server folder
Try follow this tutorial as its the same principles [TUTORIAL] How to deploy a NextJS website on CyberPanel and report back here
This solution does not work with Angular App
I believe you are trying to deploy different types of apps in same website with same instructions.
One is a SPA another is SSR.
So you need to deploy them separately e.g. myangularapp.com for static app that is deployed with instructions like Angular SSR now Running On Cyberpanel - #5 by josephgodwinke just like a html site
AND api.myuniversalangularapp.com that can be deployed with PM2 as seen here [TUTORIAL] How to deploy a NextJS website on CyberPanel OR [TUTORIAL] How to deploy a AdonisJS Application on CyberPanel
Thanks fot your efforts
I have two apps first one is django already deployed
second one is angular app
ssr is library i have been used in angular for SEO
and after generate ssr in angular app i got two folder first is browser which it has html and running website files.
and second is server folder which is running for SEO
now i used browser folder to run the website and it working
the server folder i do not know how can i run it on cyberpanel this folder has only js files
@josephgodwinke @usmannasir
Dear Sir,
Is there any solution,
Thanks.
