Redhat didnt discontinued it. They turned centos to centos stream making a different route. Centos before 2021 was cloned from RHEL but with CentOS stream RHEL is now available as subscription (paid).
The community was really disappointed with this move by Redhat.
To continue the CentOS legacy, cloudlinux team forked CentOS8 and created Almalinux and promised it as forever free RHEL based distro.
CentOs co-founder later announced Rockylinux to continue the legacy of CentOs.
Almalinux and Rockylinux will replace all CentOs server users offering enterprise grade RHEL based platform.
Performance is better in Almalinux especially the server reboot time. I have tested in 2 production servers where I have Ubuntu 20.4 LTS and Almalinux 8.5 in another and I experienced better reboot speed in almalinux as major performance changes.
Its not just limited to boot time speed, but in general too its faster performing than with ubuntu but not major difference. The boot time though was major difference.
I voted for Ubuntu. Iāve used this operating system for a long time. Iāve also used CentOS. I always come back to Ubuntu. It has always been very stable for me. I still have a server with Ubuntu 16 on it, since 2016.
I think this really all boils down to personal preference in the end. All operating systems mentioned are good and can be used to achieve the same end goal.
Yes, its all user preference. If the user expects stable, high performing server-based requisites, then the Red Hat is the best option to move for. In case the user sticks with a frequently updated, user-friendly GUI system, then comparatively, Ubuntu stands well. So clearly, the need of the user affects the choice of OS.
I find insteresting your affirmation that Almalinux is better in performance.
I have tested Ubuntu 20 and Almalinux and I get 150 ms TTFB with Ubuntu, and 500 ms with Almalinux, same website. Both Cyberpanels fresh installed and website restored from same backup. Both servers in same cloud platform.
Did you tune your Almalinux?
TTFB depends on various factors inclusive. Which hosting provider are you using? I am using AWS.
Also I never mentioned almalinux outperforms other OS drastically. Its just a marginal difference which may not be felt in real world experience. But the boot time is indeed faster with almalinux compared to ubuntu. Obviously the main reason for faster reboot and search operations is because of lesser files in RHEL based os compared to ubuntu. Ubuntu has lot of updates, plugins, and many programs pre-installed whereas almalinux is limited with these. For example, wget and nano isnt pre-installed in almalinux.
Well, itās a cloud virtual machine, 4 core, 8gb ram, nmve⦠same provider both, same network. One with Ubuntu 20 and another with Almalinux 8.5
I like the idea to migrate to Almalinux to have less updates and more stable system, but Iām confused wit this strange performance difference. At the moment I stay with Ubuntu.
Today Iāve made another test and I thought youād like to know.
A new provider, same VPS installed first with Almalinux and Cyberpanel.
And then with Ubuntu and Cyberpanel. Same Prestashop production site.
Ubuntu was hands down faster almost x3. TTFB 600ms (more than 500ms Firefox shows a turtle) vs 200 ms with Ubuntu.
GTMetrix was also confirming the performance difference.
I think this has nothing to do with Cyberpanel.
Iād be curious to see the same test with CentOS.
Also, the best test would be to do this on the exact same vps server, rather than just the same host. It is common for there to be performance differences between servers on the same host.
Perhaps you could either wipe/reinstall the server when youāve completed one test, or just take a snapshot right after deploying the server, which you can restore after a test and the install the other OS.
This seems very strange, your Linux distro shouldnāt have much effect on a sites TTFB at all, as long as the server, i.e. LiteSpeed, is set up correctly.
I know, very strange. But these are my results. Two different cloud providers, same VPS installed with Almalinux 8.5, immediately after Cyberpanel, backup restored and test. Then reinstall with Ubuntu 20 LTS and Cyberpanel and test.
I did not change anything in PHP or any other config.
Then the second provider, first Almalinux, then Ubuntu and then CentOS 8. Same VPS box. Almalinux and Cent OS showed same TTFB.
Maybe Iām forgetting something. If one of you can do some test with a Prestashop or Magento (something heavier than Wordpress)⦠Iād love to be wrong.
Sounds like a CentOS issue then. Whether itās CentOS itself or CentOS +CyberPanel is the question. Can you install almalinux/CentOS and cyberpanel on one instance, and with a different control panel on another? Maybe directadmin or cPanel, if they have a free trial?
It is stable but I would not recommend for any newbies to shift to alma or any other OS apart from ubuntu . The reason for the same is, Ubuntu and Almalinux or Centos is entirely different than ubuntu and the file contents of few config files are different for both systems. It will be tough for newbies to edit the config files if required as sometimes the location path of these config files too are different in both systems.
You will find more articles related to ubuntu OS than centos or RHEL based.
