Closed [Solved]Not allowed to move in this path, please choose location inside home!
an
antivirusadmin #1
Hi
I crated new os and installed cyberpanel in clean os last day
restored zip files from old host to cyberpanel but from file manager I got this error when I want to extract :
So with CLI I unzip the file and found somewhere that cyberpanel admin told to some other guy to use Fix Permissions
Now I upload another file from cyberpanel and want to unzip , again that problem and error
even I chose the Fix Permissions on that file , even the folder , and also rename the file name but still have problem and have no Idea to fix that , only cli can help.
Please tell me what I missed or did worng?
an
antivirusadmin #3
That wasn’t worked
This is better
sh
shoaibkk #4
Please also mention from where to where you are moving?
an
antivirusadmin #5
@shoaibkk
in Directadmin I crate manually the public_html zip
Then I moved the zip file to cyberpanel and tried to unzip that and it show me the
Then I used the CLI command to unzip the file
now in my cyberpanel all permission should be drwxr-xr-x but in my cp permissions are like this : drwxr-x--- even I changed the theme manually in cli and cannot extract any zip file from cp.
Also there is problem in WordPress that is related that above , can not upload the plugin or theme , it gives the error of
an
antivirusadmin #7
@ MyIDKaTePe
You didn’t find any useful solution for this ?
Now I facing new issue , gtmetrix show me the 300 request and many of them are belong to 404.html !
MK
Mirza Khadnezar S [sick] #8
none
no solution yet
extract using MC with no problem
that mean FM plugin problem
AT
Abdelhadi Touil #9
The same issue here with a fresh installation on a VPS running Ubuntu 20.04 and CyberPanel 2.3.1. Hope the CyberPanel team fixes it soon.
AT
Abdelhadi Touil #10
What do you mean by MC, please?
AT
Abdelhadi Touil #13
But I don’t have any installed WordPress on it yet, I have just installed CyberPanel and configured it and tried to upload WordPress files to install it as I always prefer to do it manually, but I wasn’t able to continue because of this issue. I didn’t try to upload files using SSH or SFTP, as I don’t need to face problems after installing WordPress, so I was looking for a fix to the issue until I see it is a bug.
AT
Abdelhadi Touil #14
Thank you so much, this is the first time I know about it :grinning:
AT
Abdelhadi Touil #17
PHP 7.4 and WordPress 5.9.3 (Latest).
MK
Mirza Khadnezar S [sick] #18
try php 8.0
then rstart php services and openlitespeed
because this is happen to me too
but not all domain :frowning:
