Kais
#1
Installation of imunify out of Cyperpanels GUI failed. I do a lot of testing on different installations.
I figured out, that ubuntu will not install, because the public key for the used imunify repo is missing in the ubuntu keyservers.
My qucik workaround:
Manual installation of the missing key over CLI before you start the imunify installation
- In CLI (Ubuntu / CentOS) do:
wget https://repo.imunify360.cloudlinux.com/defense360/RPM-GPG-KEY-CloudLinux
2a) In ubuntu add the key:
apt-key add RPM-GPG-KEY-CloudLinux
2b) In CentOS add the key:
rpm --import RPM-GPG-KEY-CloudLinux
After this you should be able to install Imunify over cyberpanels GUI without any issues
Best regards,
Kai
Cloudlinux said they are rolling out updates to fix this issue.
Best regards,
Kai
Thank you very much, this tutorial went well
